For those familiar, comma.ai is a company that offers a device, similar to a dashcam, that can drive your car fairly autonomously.
This integration uses their API to pull some info into HASS.
See more docs on GitHub. The integration is available in HACS!
thats very cool, will check it out (c3x/21 bolt+pedal+frog)
edit: hmm I did the jwt thing and got a code, but how does that code link to the c3x ?
edit2: ok I figured it out, I did not remember what or if I logged in to when the comma was first set up, and I used the wrong one…
but you need to find your account @ https://connect.comma.ai/
if you don’t remember which you originally used, try all 3.
once you have logged in to connect, you should see your device/vehicle and your drives.
then you can log in to @ https://jwt.comma.ai/ using the same account login, this will give you a one line page with the token, paste that token into the integration, then your comma/vehicle should show up in HA.
might be helpful to add this info to your repo
