Command Class Basic Error
Pressing the first button on the Logic Group Matrix switch gives an error
Cannot find endpoint map to instance for Command Class COMMAND_CLASS_BASIC endpoint 1
As you can see from the log the error takes several seconds to handle. As a result the scene data I’m interested in is delayed.
2019-11-03 00:19:47.424 Detail, Node007,   Received: 0x01, 0x09, 0x00, 0x04, 0x08, 0x07, 0x03, 0x20, 0x03, 0x00, 0xdd
2019-11-03 00:19:47.425 Detail,
2019-11-03 00:19:47.426 Info, Node007, Received Basic report from node 7: level=0
2019-11-03 00:19:47.426 Detail, Node007, Refreshed Value: old value=255, new value=0, type=byte
2019-11-03 00:19:47.426 Detail, Node007, Changes to this value are not verified
2019-11-03 00:19:47.426 Detail, Node007, Notification: ValueChanged
2019-11-03 00:19:47.445 Detail, Node007,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x07, 0x03, 0x20, 0x03, 0x00, 0xd5
2019-11-03 00:19:47.446 Detail,
2019-11-03 00:19:47.446 Info, Node007, Received Basic report from node 7: level=0
2019-11-03 00:19:47.447 Detail, Node007, Refreshed Value: old value=0, new value=0, type=byte
2019-11-03 00:19:47.447 Detail, Node007, Changes to this value are not verified
2019-11-03 00:19:47.447 Detail, Node007, Notification: ValueChanged
2019-11-03 00:19:51.735 Detail, Node007,   Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x07, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x20, 0x03, 0x00, 0xb8
2019-11-03 00:19:51.735 Error, Node007, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_BASIC endpoint 1
2019-11-03 00:19:51.754 Detail, Node007,   Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x07, 0x05, 0x5b, 0x03, 0x65, 0x80, 0x01, 0x4e
2019-11-03 00:19:51.755 Detail,
2019-11-03 00:19:51.755 Info, Node007, Received Central Scene set from node 7: scene id=1 in 7680 seconds. Sending event notification.
2019-11-03 00:19:51.755 Detail, Node007, Initial read of value
2019-11-03 00:19:51.756 Detail, Node007, Notification: ValueChanged
I’m not really how to proceed from here. Any pointers?
Below is the zwave config for the switch:
<Node id="7" name="" location="" basic="4" generic="24" specific="1" roletype="5" devicetype="5632" nodetype="0" type="Basic Wall Controller" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
		<Manufacturer id="234" name="Logic Soft">
			<Product type="3" id="121" name="Unknown: type=0003, id=0121" />
		</Manufacturer>
		<CommandClasses>
			<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="5">
				<Instance index="1" />
				<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="255" />
			</CommandClass>
			<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="5" innif="true">
				<Instance index="2" endpoint="1" />
				<Instance index="3" endpoint="2" />
				<Instance index="4" endpoint="3" />
				<Instance index="5" endpoint="4" />
				<Instance index="6" endpoint="5" />
				<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
				<Value type="bool" genre="user" instance="2" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
				<Value type="bool" genre="user" instance="3" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
				<Value type="bool" genre="user" instance="4" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
				<Value type="bool" genre="user" instance="5" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
				<Value type="bool" genre="user" instance="6" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
			</CommandClass>
			<CommandClass id="38" name="COMMAND_CLASS_SWITCH_MULTILEVEL" version="4" request_flags="1" after_mark="true" innif="true">
				<Value type="byte" genre="user" instance="1" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="42" />
				<Value type="button" genre="user" instance="1" index="1" label="Bright" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="button" genre="user" instance="1" index="2" label="Dim" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="bool" genre="system" instance="1" index="3" label="Ignore Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
				<Value type="byte" genre="system" instance="1" index="4" label="Start Level" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
			</CommandClass>
			<CommandClass id="51" name="COMMAND_CLASS_COLOR" version="1" request_flags="3" innif="true" colorchannels="28">
				<Value type="string" genre="user" instance="1" index="0" label="Color" units="#RRGGBB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="#7F0000" />
				<Value type="list" genre="user" instance="1" index="1" label="Color Index" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="17" size="0">
					<Item label="Off" value="0" />
					<Item label="Cool White" value="1" />
					<Item label="Warm White" value="2" />
					<Item label="Red" value="3" />
					<Item label="Lime" value="4" />
					<Item label="Blue" value="5" />
					<Item label="Yellow" value="6" />
					<Item label="Cyan" value="7" />
					<Item label="Magenta" value="8" />
					<Item label="Silver" value="9" />
					<Item label="Gray" value="10" />
					<Item label="Maroon" value="11" />
					<Item label="Olive" value="12" />
					<Item label="Green" value="13" />
					<Item label="Purple" value="14" />
					<Item label="Teal" value="15" />
					<Item label="Navy" value="16" />
					<Item label="Custom" value="17" />
				</Value>
				<Value type="int" genre="system" instance="1" index="2" label="Color Channels" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="28" />
				<Value type="int" genre="system" instance="2" index="2" label="Color Channels" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="system" instance="3" index="2" label="Color Channels" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="system" instance="4" index="2" label="Color Channels" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
				<Value type="int" genre="system" instance="5" index="2" label="Color Channels" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
			</CommandClass>
			<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="5" innif="true">
			</CommandClass>
			<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="5" innif="true" scenecount="4">
				<Instance index="1" endpoint="0" />
				<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="4" />
				<Value type="int" genre="user" instance="1" index="1" label="Single activation" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="7680" />
				<Value type="int" genre="user" instance="1" index="2" label="Release button" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="7860" />
				<Value type="int" genre="user" instance="1" index="3" label="Hold button" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="7680" />
				<Value type="int" genre="user" instance="1" index="4" label="Double activation" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="7680" />
			</CommandClass>
			<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="5" innif="true">
				<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="1" />
				<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="5632" />
				<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="5632" />
				<Value type="byte" genre="system" instance="2" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="short" genre="system" instance="2" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="short" genre="system" instance="2" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="byte" genre="system" instance="3" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="short" genre="system" instance="3" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="short" genre="system" instance="3" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="byte" genre="system" instance="4" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="short" genre="system" instance="4" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="short" genre="system" instance="4" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="byte" genre="system" instance="5" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="short" genre="system" instance="5" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="short" genre="system" instance="5" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="byte" genre="system" instance="6" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="short" genre="system" instance="6" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="short" genre="system" instance="6" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
			</CommandClass>
			<CommandClass id="96" name="COMMAND_CLASS_MULTI_INSTANCE/CHANNEL" version="4" request_flags="1" innif="true">
			</CommandClass>
			<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="5" innif="true">
			</CommandClass>
			<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="5" innif="true">
			</CommandClass>
			<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="5" innif="true">
				<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Normal" value="0" />
					<Item label="-1dB" value="1" />
					<Item label="-2dB" value="2" />
					<Item label="-3dB" value="3" />
					<Item label="-4dB" value="4" />
					<Item label="-5dB" value="5" />
					<Item label="-6dB" value="6" />
					<Item label="-7dB" value="7" />
					<Item label="-8dB" value="8" />
					<Item label="-9dB" value="9" />
				</Value>
				<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="0" />
				<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
				</Value>
				<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
				<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
				<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
					<Item label="Failed" value="0" />
					<Item label="Success" value="1" />
					<Item label="In Progress" value="2" />
				</Value>
				<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-32768" max="32767" value="0" />
			</CommandClass>
			<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="5" innif="true">
				<Associations num_groups="14">
					<Group index="1" max_associations="5" label="Group 1" auto="true" multiInstance="true">
						<Node id="1" />
					</Group>
					<Group index="2" max_associations="5" label="Group 2" auto="false" multiInstance="true">
						<Node id="1" instance="1" />
						<Node id="7" />
					</Group>
					<Group index="3" max_associations="5" label="Group 3" auto="false" multiInstance="true" />
					<Group index="4" max_associations="5" label="Group 4" auto="false" multiInstance="true" />
					<Group index="5" max_associations="5" label="Group 5" auto="false" multiInstance="true" />
					<Group index="6" max_associations="5" label="Group 6" auto="false" multiInstance="true" />
					<Group index="7" max_associations="5" label="Group 7" auto="false" multiInstance="true">
					</Group>
					<Group index="8" max_associations="5" label="Group 8" auto="false" multiInstance="true" />
					<Group index="9" max_associations="5" label="Group 9" auto="false" multiInstance="true" />
					<Group index="10" max_associations="5" label="Group 10" auto="false" multiInstance="true" />
					<Group index="11" max_associations="5" label="Group 11" auto="false" multiInstance="true" />
					<Group index="12" max_associations="5" label="Group 12" auto="false" multiInstance="true">
					</Group>
					<Group index="13" max_associations="5" label="Group 13" auto="false" multiInstance="true" />
					<Group index="14" max_associations="5" label="Group 14" auto="false" multiInstance="true" />
				</Associations>
			</CommandClass>
			<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="5" innif="true">
				<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
				<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="5.03" />
				<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.01" />
			</CommandClass>
			<CommandClass id="142" name="COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION" version="1" request_flags="5" innif="true">
						<Node id="1" />
					</Group>
						<Node id="7" />
					</Group>
					</Group>
					</Group>
				</Associations>
			</CommandClass>
		</CommandClasses>
	</Node>
