Hi there,
I tried to utilize command_line sensor but didn’t get an entity.
My config is the following:
- Installation method: Home Assistant Supervised
- Core: 2025.5.2
- Supervisor: 2025.05.1
- Operating System: Armbian/Debian (Bookworm)
- Frontend: 20250516.0
I added sensor config (I changed the actual IP to 0.0.0.0) to sensors.yaml:
- platform: command_line
name: "PS5 Pro State"
unique_id: ps5_pro_state
command: "/config/bin/ps5-wake -vP -H 0.0.0.0"
# Output Options:
# Device found: PS5-132 [PS5/D4F7D5000111]: Standby
# Device found: PS5-132 [PS5/D4F7D5000111]: Home Screen
scan_interval: 3
value_template: >-
{% if 'Home Screen' in value %}
Home Screen
{% elif 'Standby' in value %}
Standby
{% else %}
Unknown
{% endif %}
I placed compiled binary at /usr/share/hassio/homeassistant/bin
And tested inside the HomeAssistant container:
homeassistant:/config# /config/bin/ps5-wake -vP -H 0.0.0.0
Also, added debug log for command_line
in configuration.yaml
# Set logging
logger:
default: info
logs:
homeassistant.components.command_line: debug
But don’t see any mentions about command_line
and the sensor itself.
Pls somebody HA Guru take a look at my config!
Thanx for any info in advance!
