Command Line Sensors Not Working
I am having some trouble displaying sensor information from Command Line Sensors. The ‘CPU Temperature’ sensor as well as the ‘Disk Space’ sensor do not show up at all in lovelace, and the ‘Supervisor Updates’ sensor shows as a temperature sensor. Anyone have any idea what is wrong with them?
- platform: command_line
  name: CPU Temperature
  command: "cat /sys/class/thermal/thermal_zone0/temp"
  unit_of_measurement: "°F"
  value_template: '{{ value | multiply(0.001) | round(1) }}'
  command: "df -h|grep -w /|awk '{ print $4 }'"
  value_template: '{{ value|regex_findall_index("\d+\.?\d+|\d+") | float }}'
  scan_interval: 3600
  command: 'curl http://supervisor/supervisor/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version,"addons":[.data.addons[] | select(.version != .installed)]}'''
  value_template: "{{ value_json.addons | length }}"
  json_attributes:
  - newest_version
  - current_version
  - addons
  scan_interval: 3600
  json_attributes:
  - newest_version
  - current_version
  - addons
Oh I did not realize you can’t nest them under one command line platform. Thank you!
