Command_line switch not working - getting mapping values ar not allowed here
im trying to send a message to a webserver via command_line switch.
Im getting the following Error:
(MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: mapping values are not allowed here
in “/home/homeassistant/.homeassistant/configuration.yaml”, line 110, column 13
here are the lines of code i’m using:
switch:
  platform: command_line
  switches:
    door:
      command_on: "/usr/bin/curl -X GET http://192.168.0.66/open.php"
Have you got more than one switch statement? If you have just number them …
switch 25:
no, only one at the moment
Which line is it complaining about?
try like mine
    command_off: 'curl -k "http://localhost/action/frontgate.php"'
Hi, got it to work now. Seemed to be a problem with the name.
For anybody that finds this thread like I did, it definitely seems to be an issue with the naming.
This works:
switch 1:
  switches:
    rokutv:
      command_on: >-
        curl -d '' http://RokuTV-IP-Here:8060/keypress/PowerOn
      command_off: >-
        curl -d '' http://RokuTV-IP-Here:8060/keypress/PowerOff
      friendly_name: RokuTV
While this does not, due to the underscore:
switch 1:
  switches:
    roku_tv:
      command_on: >-
      command_off: >-
