Commandline sensor offset
Hi all!
I’m trying to use a little temper USB temp sensor accessed through a commandline sensor config, which works well (though unreliable updates, which I think is caused by the temper software being problematic) except the sensor has a large offset from the real temperature.
I’m using this configuration:
  - platform: command_line
    name: Room Temperature
    command: "temper-poll -s 0 -c"
    # If errors occur, make sure configuration file is encoded as UTF-8
    unit_of_measurement: "°C"
    value_template: "{{ value | float | round(1)}}"
which happily returns the value to 1 decimal place, which I assume has been converted into a float and rounded. If I put “float - 1.8” the value gets subtracted from the float-ified sensor response but the “round(1)” never gets applied, and I end up with a large number of decimals which is untidy. I assume I’m doing something dodgy with the order of operators, or approaching this entirely the wrong way. Any advice please?
Solved my own problem, so in case anyone else has this basic issue:
value_template: "{{((value | float)-1.8) | round(1)}}"
the calculation needs to be entirely encased in () before the round(1).
