When an addon needs to push data or events into Home Assistant, two common approaches are MQTT and a companion integration. Each has tradeoffs.
MQTT
The addon publishes to an MQTT broker (e.g. Mosquitto). Home Assistant subscribes to topics. MQTT discovery lets the addon publish JSON configs so sensors appear automatically without YAML.
Pros:
Decoupled. The addon does not need
homeassistant_apior Supervisor access. It only needs broker credentials. -
Works when the addon runs outside HA (dev, different host). Publish to a broker; HA picks it up regardless of where the addon runs.
Standard protocol. Any MQTT client can subscribe. Easy to debug with external tools.
Discovery avoids manual YAML. Publish discovery payloads; sensors register under Devices & services → MQTT.
Cons:
Requires MQTT broker configuration in the addon. Users must set URL, credentials, base topic.
One-way. Addon pushes; it does not receive HA events or call HA services directly. For actions (e.g. TTS, automations) you must either publish to a topic and add an HA automation to handle it, or use a different channel.
Duplicates and stale sensors. Retained discovery messages can cause duplicates if topics change. You need cleanup logic (empty retained messages) to remove old sensors.
No access to HA internals. The addon cannot listen to
hass.busevents (e.g.mobile_app_notification_action), usehass.loop, or call HA services withouthomeassistant_api.
Companion Integration
The addon ships an integration and installs it into custom_components on startup. The integration runs inside HA core and polls the addon’s HTTP API or listens to events.
Pros:
Native HA integration. Appears in Devices & services. Has config flow. Can expose sensors, listen to events, call services.
Direct access to HA APIs. Can use
hass.bus.async_listen,hass.services, coordinator patterns. Event-driven flows (e.g. notification taps) work without automations. -
No MQTT broker setup. Users add the integration, enter the addon URL, done. No extra infrastructure.
Clean lifecycle. Integration is part of the addon. When the addon updates, the integration is overwritten on next start.
Cons:
Requires addon to be running. The integration calls the addon URL. If the addon is stopped or unreachable, sensors and features fail.
Write access to HA config. The addon needs
homeassistant_config:rwto copy files intocustom_components. Not all addons have this. -
One-time setup. User must add the integration (config flow) and configure the addon URL. More steps than “just enable MQTT.”
Tied to HA. The integration only runs inside HA. It cannot run standalone or on another host.
When to Use Which
Use MQTT when: the addon must work without Supervisor, runs on another machine, or needs to publish data without touching HA config. Use it for sensors and one-way publish; add automations for actions.
Use an integration when: the addon runs as a Supervisor addon and you need event handling (e.g. notification actions), direct service calls, or native config flow. The integration is the bridge from HA’s event loop to your addon API.
A hybrid is common: MQTT for sensors (especially if users already have MQTT), integration for features that require HA event or service access.
