I have problem connecting ESP32 to my homeassistance. I use Homeassitance green.
I have several ESP home projekt that works fine. They all use a Asus router.
My next projekt is outdoors at a distance of 100m from my house.
For this projekt I want to use a DecoMesh X50-Outdoor Wifi router.
It is connected with cable, to the same switch as the Homeassistance green.
I can not get it to connect to my ESP32 unit.
At the moment the units are close to each outher, for test of communication.
If I look in “Fing” the adress for the Deco unit is: 192.168.1.132
If I look in the Deco app in my phone the adress is: 192.168.68.1
I use a fixed adress for the ESP to:192.168.68.51
This is part of my yaml file:
wifi:
ssid: gramek
password: xxx
manual_ip:
#Set this to the IP of the ESP
static_ip: 192.168.68.51
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.68.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
I have also tried to set the IP for the router to 192.168.1.132
It is not working either.
I have set the yaml file to work with my Asus router. Then it works fine.
The ESP I use is with an external antenna.
I tested how far my Asus router could reach. It was about 75% of what I need.
It is located in the wrong side of my house.
The Deco is in a window that is in line of sight with were I want the ESP unit.
If it is to far I can move it to a closer house.
The problem is to get the Deco router to talk to my ESP unit.
Krister
