Home Assistant Community Add-on: AirCast
Hi! I install a home assistant’s version without the hass.io panel where i can add third repository. I would install this add-on. is there a manual installation?
Hello! I recently installed AirCast and looking through the logs it appears to be working, but when I try to find it in my AirPlay options, nothing shows up. Any advice?
Log shows as follows:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: AirCast v0.5.0
 AirPlay capabilities for your Chromecast devices.
 By: Franck Nijhof <[email protected]>
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 50-aircast.sh: executing...
[cont-init.d] 50-aircast.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
INFO: Starting the AirCast server
[08:43:46.829756] main:869 Starting aircast version: v0.2.0.8 (May  8 2018 @ 20:14:15)
[08:43:46.830096] main:877 no config file, using defaults
[08:43:46.832308] Start:657 Binding to 192.168.7.43
[08:43:46.847910] AddCastDevice:588 [0x75fe8]: adding renderer (Kitchen speaker)
[08:43:46.848054] AddCastDevice:594 [0x75fe8]: creating MAC 75ff2
[08:43:46.857008] AddCastDevice:588 [0x76450]: adding renderer (Living Room TV)
[08:43:46.857116] AddCastDevice:594 [0x76450]: creating MAC 7645a
Can you cast to your device without using this Aircast add-on? If not it may have something to do with this:
Yup no problems at all, and still not seeing the aircast devices :frowning:
What version of Hassio are you running?
I’m still on 0.71.0 and it is working as expected.
I got my Raspberry pi and installed it yesterday, so I assume latest as of yesterday (0.72.1?)
You can check the installed version by clicking on the ‘i’ in a circle button at the bottom of the left hand menu.
I’ll update to 0.72.1 later tonight and let you know how it goes.
This add-on does not interact with Home Assistant, so the version of Home Assistant doesn’t matter…
Well there goes that idea.
So, any other ideas? :slight_smile:
Have you changed anything from default in the add-on configuration options?
Sorry for the delay in responding, was away for the holidays. I havent changed any defaults at all, nope
Hi Frenk,
Just installed. This seems like it would be a very clever solution to interoperability. However, I cannot get it working. Any ideas?
Log below:
[fix-attrs.d] done.
 Hass io Add-on: AirCast v0.5.0
[cont-init.d] done.
[services.d] done.
[10:02:26.356007] main:869 Starting aircast version: v0.2.0.8 (May  8 2018 @ 20:14:15)
[10:02:26.356575] main:877 no config file, using defaults
[10:02:26.362628] Start:657 Binding to 192.168.1.217
[10:02:26.374334] AddCastDevice:588 [0x75fe8]: adding renderer (RE-SHIELD)
[10:02:26.377782] AddCastDevice:588 [0x76450]: adding renderer (Library TV)
[10:02:26.382102] AddCastDevice:588 [0x768b8]: adding renderer (Family room TV)
[10:02:26.385163] AddCastDevice:588 [0x76d20]: adding renderer (Kitchen Chromecast)
[10:02:26.395061] AddCastDevice:588 [0x77188]: adding renderer (Bedroom Chromecast)
[10:09:33.897204] mDNSsearchCallback:418 [0x76450]: removing renderer (Library TV+) 0
[10:09:34.100431] DeleteCastDevice:492 [0x76450]: Cast device stopped
[10:09:34.100877] mDNSsearchCallback:418 [0x768b8]: removing renderer (Family room TV+) 0
[10:09:34.384483] DeleteCastDevice:492 [0x768b8]: Cast device stopped
[10:09:34.385204] mDNSsearchCallback:418 [0x76d20]: removing renderer (Kitchen Chromecast+) 0
[10:09:34.617228] DeleteCastDevice:492 [0x76d20]: Cast device stopped
[10:09:34.617949] mDNSsearchCallback:418 [0x77188]: removing renderer (Bedroom Chromecast+) 0
[10:09:34.917642] DeleteCastDevice:492 [0x77188]: Cast device stopped
[10:10:31.819249] mDNSsearchCallback:418 [0x75fe8]: removing renderer (RE-SHIELD+) 0
[10:10:32.128216] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:12:42.889165] AddCastDevice:588 [0x75fe8]: adding renderer (RE-SHIELD)
[10:12:42.890761] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:12:42.891400] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (RE-SHIELD+)
[10:12:43.190833] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:12:43.192113] AddCastDevice:588 [0x75fe8]: adding renderer (Library TV)
[10:12:43.193582] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:12:43.193854] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (Library TV+)
[10:12:43.493813] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:12:43.494511] AddCastDevice:588 [0x75fe8]: adding renderer (Family room TV)
[10:12:43.495621] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:12:43.495970] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (Family room TV+)
[10:12:43.600654] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:12:43.601050] AddCastDevice:588 [0x75fe8]: adding renderer (Kitchen Chromecast)
[10:12:43.601502] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:12:43.601653] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (Kitchen Chromecast+)
[10:12:43.901674] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:12:43.902026] AddCastDevice:588 [0x75fe8]: adding renderer (Bedroom Chromecast)
[10:12:43.902469] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:12:43.902587] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (Bedroom Chromecast+)
[10:12:44.202687] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:14:43.626371] AddCastDevice:588 [0x75fe8]: adding renderer (RE-SHIELD)
[10:14:43.627220] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:14:43.627381] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (RE-SHIELD+)
[10:14:43.927292] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:14:44.973488] AddCastDevice:588 [0x75fe8]: adding renderer (Library TV)
[10:14:44.974033] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:14:44.974193] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (Library TV+)
[10:14:45.274283] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:14:45.274615] AddCastDevice:588 [0x75fe8]: adding renderer (Family room TV)
[10:14:45.275570] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:14:45.275891] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (Family room TV+)
[10:14:45.375426] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:14:45.375675] AddCastDevice:588 [0x75fe8]: adding renderer (Kitchen Chromecast)
[10:14:45.376723] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:14:45.377031] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (Kitchen Chromecast+)
[10:14:45.676984] DeleteCastDevice:492 [0x75fe8]: Cast device stopped
[10:14:45.677490] AddCastDevice:588 [0x75fe8]: adding renderer (Bedroom Chromecast)
[10:14:45.678745] raop_create:128 Cannot bind or listen RTSP listener: Cannot assign requested address
[10:14:45.679254] mDNSsearchCallback:471 [0x75fe8]: cannot create RAOP instance (Bedroom Chromecast+)
[10:14:45.978683] DeleteCastDevice:492 [0x75fe8]: Cast device stopped`Preformatted text`
HI Everyone,
I have installed the home assistant and the aircast plugin… however i see in the logs its unable to start the AirCast server…
PROTINFO: Starting the AirCast server
PROTINFO: Starting the AirCast se…
Is anyone able to help please?
Guys, please use code blocks…
Secondly, use GitHub for reporting issues. Be sure to provide sufficient information (like the hardware used, OS used).
Hi Guys,
Thank you for sharing your time and experiences! This is exactly what I was looking for :slight_smile:
I successfully installed Home Assistant and the AirCast plugin on a Raspberry PI2 yesterday. Google Home Minis clearly appear as airplay devices and I can easily stream to them - either individually, or grouped. However, I’m experiencing a delay, Google Homes are behind other Airplay speakers - is this something others have found/resolved?
Ryan
Running into the same issue here as well - keeps repeating ‘PROTINFO: Starting the Aircast Server’ - going to try out a few things.
Running RP3, HassOS 1.7
The issue is known, and tracked on GitHub. Still trying to find a solution for this one.
appreciate it!
This is to be expected and unfixable. The add-on acts as an bridge, so it has to receive, quite possibly transcode, and send it out again. This will alway introduce delay.
