Thanks very much for your quick response.
Same problem here.
18-05-06 07:40:18 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
18-05-06 07:40:18 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 381, in start
resp = await self._request_handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web_app.py", line 322, in _handle
resp = await handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 88, in impl
return await handler(request)
File "/usr/lib/python3.6/site-packages/hassio/api/security.py", line 36, in token_validation
File "/usr/lib/python3.6/site-packages/hassio/api/proxy.py", line 108, in api
client = await self._api_client(request, path)
File "/usr/lib/python3.6/site-packages/hassio/api/proxy.py", line 37, in _api_client
method = getattr(self._websession_ssl, request.method.lower())
File "/usr/lib/python3.6/site-packages/hassio/coresys.py", line 269, in __getattr__
raise AttributeError()
AttributeError
and here:
2018-05-06 10:43:25.540223 INFO AppDaemon: HASS: Connected to Home Assistant 0.68.1
2018-05-06 10:43:25.659151 WARNING AppDaemon: HASS: Error getting metadata
2018-05-06 10:43:25.667611 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-05-06 10:43:30.698605 INFO AppDaemon: HASS: Connected to Home Assistant 0.68.1
2018-05-06 10:43:30.787957 WARNING AppDaemon: HASS: Error getting metadata
2018-05-06 10:43:30.794282 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-05-06 10:43:35.824375 INFO AppDaemon: HASS: Connected to Home Assistant 0.68.1
2018-05-06 10:43:36.045170 WARNING AppDaemon: HASS: Error getting metadata
2018-05-06 10:43:36.055609 WARNING AppDaemon: HASS: Disconnected from Home Assistant, retrying in 5 seconds
2018-05-06 10:43:36.065153 WARNING AppDaemon: Unexpected error refreshing default state - retrying in 10 minutes
Guau, that was fast! Thank you very much, Sir!
Youāre doing a fantastic, awesome, and enormous job with the Hassio add-ons, please continue
Solved after 103.2. Thank you.
Legend. This worked for me also
Thank you so much working now. How can we keep the supervisor from auto updates? Problems like this are a prime example of why auto update can be horrible as all my automations went down with this supervisor update and I had no idea an update was even coming.
@josephkiser04 I am totally on your side. I personally do not agree with the auto update function of Supervisor.
Currently, there is not sane way to disable or manually auto update.
@frenck would putting in a feature request for this be a good idea? I know something like this is more of a design philosophy than a feature sometimes so I didnāt know if the request would have any bearing or impact.
Release v1.1.0
This release is exciting, at least, for me it is. Iāve been working on this for months! And for you? Well, almost nothing changed
So what did change? Iāve updated the workflows of the Community Hass.io Add-ons project. Things include:
- Replaced CircleCI and CodeClimate. We are now using GitLab CI, backed by a couple of custom servers building and testing these add-ons.
- All add-ons are now scanned during built and release by Clair to prevent security issues in our add-ons.
- All add-ons are constantly scanned and monitored by Anchore.io. We will be notified immediately in case of security issues occur. (Major thanks to Anchore.io for helping us out!)
- The add-ons repository is now entirely generated and automatically synced with all the add-ons. This ensures repositories are in sync, never forgotten and releases are almost instantly.
- The base images that these add-ons are built on are entirely revised.
- All add-ons have been updated to follow the Docker best practices. These are checked on every code change by GitLab CI.
- All add-ons had maintenance. All software is updated to the latest and greatest and the documentation has been revisited.
- There are now 2 bots in place on the GitHub project. The Add-ons Assistant is helping us out with the GitHub issues and pull requests and the AddonsBot is fully active taking care of updating code across the different GitHub Repositories.
- We now have Edge & Beta add-ons repositories available. This allows everybody to test the latest and greatest (in case you donāt care about stability that much, or just wanna help out!)
- Iāve removed all the PayPal, Bitcoin, ā¦ buttons. If youād like to show your appreciation, then please, just buy me a coffee.
So thatās quite a lot, right? So what changed in this specific add-on?
Added
- Adds .yamllint configuration
- Adds all architectures to add-on config
- Adds Probot configuration
- Adds add-on README template
- Adds Gitlab CI
Fixed
- Fixes Markdownlint warning in License
- Fixes hadolint warnings
Changed
- Replaces Changelog with GitHub releases
- Updates README
- Upgrades add-on base image to v1.4.1
- Renames AppDaemon3 back to AppDaemon
Removed
- Removes CodeClimate
- Removes CircleCI
- Removes supervisor version constraint from add-on config
The addon seems to overwrite the ha_key when it restarts. I tried to replace it with:
ha_key: !secret home_assistant_key
But it is replaced by the actual key whenever the plugin starts.
I donāt really understand the consequences of this, Iām just trying to clean up my repo before publishing it on github (I have some custom widgets to share).
This is a known issue - I just havenāt got around to fixing it yet.
This is actually an issue with the add-on. Not AppDaemon.
Created an issue in the add-on repository to fix it:
Hi Franck,
I would like to thank for such a beautiful extension. It extends Hassio to the next level.
I have one query:
I have crated a files called flashLight.py , hello.py and apps.yaml under ā**HASSIO\config\appdaemon\apps**ā folder
And apps.yaml has below content
flash_Light:
module: flashLight
class: FlashyMotionLights
hello_world:
module: hello
class: HelloWorld
Now I am not seeing any thing on my dashboard.
I have created a Automation.dash under ā\HASSIO\config\appdaemon\dashboardsā
has content
Main arguments, all optional
title: Flashlight
widget_dimensions: [122, 120]
widget_margins: [5, 5]
columns: 8
#skin = green
Includes (Optional)
layout:
- include: /config/apps/apps
But I can not see anything in my dash board.
Only the Automation link is showed. But a blank page when opened, no content inside itā¦
Please suggest ā¦I guess I am missing something here.
How can I link my automation to dashboard ā¦??
Thanks,
MJ
i am sorry to dissapoint you, but appdaemon was not created by frenck, but by @aimc
and what you are trying to do is impossible.
the dashboard is there to view entities that exist in HA.
the apps are to create automations.
i think you better take a look at the documents about how to create a dashboard
http://appdaemon.readthedocs.io/en/latest/DASHBOARD_CREATION.html
any other questions about apps or the dashboard you can better ask in a new topic in the subforum appdaemon or hadashboard, because this topic is about the hassio addon (which is a wrapper for appdaemon/hadashboard to use it on the hassio platform)
sorry.
I have created the Dashboad which displays the things(entities that exist in HA) , But now I want to attach the automation(Apps) in Dashboard. Is that a possibility. I can crate a new topic for it.
sorry, but you cant attach apps to a dashboard.
apps are no entities and have no state, so you cant view an app.
you can however start and stop apps by using an input_boolean constraint
the input boolean then can be put on your dashboard.
Thanks for the clarification.
Release v1.1.1
Added
- Adds support for having ha_key loaded from secrets file (#16)
Fixed
- Fixes expanding secrets string check
