Just in case anyone has the same problem I had, and no devices were tracked anymore.
The new 1.8.2 presence server has a new config setting: RSSI minimum threshold, which is set to -90.
If your devices dont show up, try to set “RSSI minimum threshold” in the settings section to a higher value
Yeah!, graeat job
I have updated but it still shows 1.8.1 at the top of the web ui page. Not sure if that’s a bug or not
@frenck let me know if you any thing else
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Happy Bubbles v0.4.0
Presence detection server for Happy Bubbles Bluetooth beacon-based presence detection system.
By: Franck Nijhof <[email protected]>
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing...
[cont-init.d] 10-requirements.sh: exited 0.
[cont-init.d] 11-nginx.sh: executing...
[cont-init.d] 11-nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
_ _ _ ____ ______ __ ____ _ _ ____ ____ _ _____ ____
| | | | / \ | _ \| _ \ \ / / | __ )| | | | __ )| __ )| | | ____/ ___|
| |_| | / _ \ | |_) | |_) \ V / | _ \| | | | _ \| _ \| | | _| \___ \
| _ |/ ___ \| __/| __/ | | | |_) | |_| | |_) | |_) | |___| |___ ___) |
|_| |_/_/ \_\_| |_| |_| |____/ \___/|____/|____/|_____|_____|____/
CONNECTED TO MQTT
Visit http://0.0.0.0:3000 on your browser to see the web interface
detected a change!!! main.Beacon{Name:"happy-bubbles-beacon-1", Beacon_id:"e2c56db5dffb48d2b060d0f5a71096e0_0000_0000", Beacon_type:"ibeacon", Beacon_location:"", Last_seen:1529232795, Incoming_JSON:main.Incoming_json{Hostname:"ble_detector", MAC:"ff7dc5c230d3", RSSI:-58, Is_scan_response:"", Ttype:"", Data:"", Beacon_type:"ibeacon", UUID:"e2c56db5dffb48d2b060d0f5a71096e0", Major:"0000", Minor:"0000", TX_power:"c5", Namespace:"", Instance_id:"", HB_ButtonCounter:0, HB_Battery:0, HB_RandomNonce:"", HB_ButtonMode:""}, Distance:0, Previous_location:"", Previous_confident_location:"ble_detector", Location_confidence:8, beacon_metrics:[]main.beacon_metric{main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"", distance:0, rssi:0, timestamp:0}, main.beacon_metric{location:"ble_detector", distance:0.7083182641128207, rssi:-57, timestamp:1529232787}, main.beacon_metric{location:"ble_detector", distance:0.842868491626227, rssi:-58, timestamp:1529232788}, main.beacon_metric{location:"ble_detector", distance:0.842868491626227, rssi:-58, timestamp:1529232789}, main.beacon_metric{location:"ble_detector", distance:0.842868491626227, rssi:-58, timestamp:1529232790}, main.beacon_metric{location:"ble_detector", distance:0.842868491626227, rssi:-58, timestamp:1529232791}, main.beacon_metric{location:"ble_detector", distance:0.842868491626227, rssi:-58, timestamp:1529232793}, main.beacon_metric{location:"ble_detector", distance:0.7083182641128207, rssi:-57, timestamp:1529232794}, main.beacon_metric{location:"ble_detector", distance:0.842868491626227, rssi:-58, timestamp:1529232795}}, HB_ButtonCounter:0, HB_Battery:0, HB_RandomNonce:"", HB_ButtonMode:""}
det
Sorry about this, I rushed the feature and this was a bad result.
I’ve just released a new 1.8.3 version which addresses this and lets you choose from the web UI whether to enforce an RSSI minimum threshold or not.
It also lets you see all your added beacons on your home screen, regardless if they’ve been seen recently or not.
@frenck I created a pull request for your add-on repo for the new version
@matust showing a stale version in the web UI might be a cache issue. Refresh while holding the shift or crtl button to refresh everything and it should update to your current version.
This worked, cheers
Release v1.0.0
Changed
- Upgrades base image to v2.0.1
- Upgrades nginx to 1.14.0-r0
- Updates project badges to production ready
Release v1.1.0
Now supports the use of your Home Assistant secrets file! So you can now use !secret mqtt_password
as your password and the add-on will fetch the actual password from your secrets file.
Added
- Adds support for using secrets
Fixed
- Fixes Markdownlint warnings
Changed
- Enables SSL by default
- Upgrades hadolint to latest
- Upgrades base image to v2.1.1
- Updates README and links
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Add-on doesn’t work anymore since yesterday. Doesn’t auto start on boot, web ui hassio.local:5555 is offline. I suspect it has something to do with the v1.1.0 update. I had it on auto-update. Didn’t change anything to my HA config or setup recently. Any ideas?
[fix-attrs.d] done.
Hass.io Add-on: Happy Bubbles v1.1.0
armhf / Resin OS 2.3.0+rev1 / HA 0.73.2 / SU 125 / stable
FATAL: The configured certfile is not found
[cont-init.d] 10-requirements.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
s6-maximumtime: warning: unable to wait for child process: Operation timed out
v1.1.0 / armhf / Resin OS 2.3.0+rev1[cont-finish.d] 99-message.sh: exited 99.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
Upgraded to HA 0.76, no difference. Also tried removing and reinstalling the add-on.
Do you have SSL set to true in the addon config?
If so, does your config also point to a working certfile?
Wonderful! That’s it. Not sure if this setting was pushed by the update, haven’t changed it. In any case, this is fixed now, by changing it to ‘false’. Thanks a lot.
No worries, always check the changelogs:
Release v1.1.1
Changed
- Upgrades base image to v2.1.2
How you do guys use the sensors on HASS? I’m usng the add-on and I’ve tried setting up a room sensor as such:
- platform: mqtt_room
state_topic: 'happy-bubbles/presence/ha/happy-bubbles-ble'
device_id: '36e7e92ee4b35d_0000_0001[redacted]'
name: "Patrik ibeacon_v1"
timeout: 5
away_timeout: 60
When I subscribe to the channel above, this is what I get:
"id":"36e7e92ee4b35d_0000_0001[redacted]",
"name":"Patrik",
"distance":0.004230491648658655
And finally, this is what Home Assistant shows me:
Given the config and json output, shouldn’t I expect to see a distance here?
Release v1.2.0
Changed
- Upgrades unzip to 6.0-r4
- Upgrades nginx to 1.14.0-r1
- Upgrades base image to v2.3.0
- Adds Hassio API security role
Just installed one of these. I can go in config and put my WiFi ssid, password and MQTT configuration
It does connect, but the only message it publish is this below (the status topic)
{“rssi”:-49, “heap_free”:28056}
and re publish every 60 second. LED turns red, and nothing is shown in happy bubbles server.
Any clue?
I am having the exact same issue, how did you solve?
The mqtt topic I put when in config is living-hb
