Home Assistant Community Add-on: Log Viewer
Well you can’t do that with the log viewer… it’s purely real-time. You can always open the log file in a normal text editor…
Same happening to me. Did you ever get this fixed?
:tada: Release v0.4.0
Full Changelog
Changed
  • :arrow_up: Upgrades NodeJS to 10.14.2-r0
  • :arrow_up: Upgrades git to 2.20.1-r0
  • :hammer: Makes log_level optional
  • :fire: Removes custom log format override
  • :ambulance: Workaround Docker issue by reinstating legacy tags
  • :sparkles: Adds support for ARMv7
  • :hammer: Rewrite add-on onto Bashio
  • :shirt: Fixes Markdownlint warnings
  • :arrow_up: Upgrades add-on base image to 3.0.1
:tada: Release v0.4.1
Full Changelog
Changed
  • :ambulance: Adds explicit architecture definition
I love this add-on it makes log viewing so easy.
If i haven’t made a mistake in the setup (which i have checked multiple times) i have a request to make it more easy to toogle between log level.
Right now the setting in logger is overwriting the setting i log viewer, so if i set the level to info in logger and warn in log viewer it shows log level info.
It would be awesome to be able to set the log level in logger to debug, and in log viewer be able to change what the log viewer actually shows, by changing the log level from the add-on.
:tada: Release v0.5.0
Full Changelog
:sparkles: This release adds support for Hass.io Ingress :tada:
Breaking change
The addition of Ingress makes this add-on not accessible directly. If you have added the Log Viewer via an iframe panel, this release will break that.
However, you can enable this again by going into the add-on configuration. A new section show is visible: “Network”. Enter port 4277 (or anything else if you want) in the disabled field. Hit the “SAVE” followed by the “RESTART” button to make your iframe work as before.
An option to add an Ingress capable add-on to the sidebar menu automatically is expected to land in Home Assistant 0.92.
Changed
  • :books: Updates documentation
  • :arrow_up: Upgrades base image to v3.1.0
  • :sparkles: Adds Hassio Ingress support
:tada: Release v0.5.1
Full Changelog
:sparkles: This release adds support for the “Add to sidebar” feature that became available in Home Assistant 0.92.
Please note: You need to have Home Assistant 0.92 or newer to be able to install this update.
Changed
  • :arrow_up: Updates Home Assistant requirement to 0.92.0b2
  • :sparkles: Adds support for showing in sidebar
Hi, is it possible to use this add-on to view the zwave log? if yes, how? Thanks!
:tada: Release v0.6.0
Full Changelog
This release upgrades the internals of the add-on.
No breaking changes.
Changed
  • :ambulance: Turns off Lua Resty core in Nginx
  • :arrow_up: Upgrades nginx to 1.16.0-r2
  • :arrow_up: Upgrades nodejs to 10.16.0-r0
  • :arrow_up: Upgrades npm to 10.16.0-r0
  • :arrow_up: Upgrades git to 2.22.0-r0
  • :arrow_up: Upgrades add-on base image to v4.0.1
  • :fire: Removes now deprecated ssl directive
  • :pencil2: Maintaince -> Maintenance
I’m having some difficulty getting this add-on started on hassio 0.94.4. The log shows only the following error which a web search tells me has something to do with s6-overlay and docker that I don’t quite follow.
execlineb: fatal: unable to exec /etc/s6/init/init-stage2: Exec format error
This is all I have in my config:
  "ssl": false,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem"
:tada: Release v0.6.1
Full Changelog
This is a maintenance release.
Changed
  • :arrow_up: Upgrades add-on base image to v4.0.2
:tada: Release v0.6.2
Full Changelog
Changed
  • :arrow_up: Upgrades add-on base image to v4.0.3
:tada: Release v0.6.3
Full Changelog
Changed
  • :arrow_up: Upgrades nginx to 1.16.1-r0
  • :hammer: Updates HA Auth URL in NGinx LUA script
  • :arrow_up: Upgrades add-on base image to v4.1.1
  • :ambulance: Fixes path handling for SSL certificates
  • :hammer: Use Hass.io DNS as NGinx resolver
:tada: Release v0.6.4
Full Changelog
Changed
  • :arrow_up: Upgrades add-on base image to v5.0.1
  • :arrow_up: Upgrades nodejs to 10.16.3-r0
  • :arrow_up: Upgrades npm to 10.16.3-r0
I have a problem that log viewer only show once after restart addon. Again when i try open show only black screen. Where is a problem ?
Please, help me, where can I find some info how to show LogViewer in sidebar?
-----> Don’t bother: I’ve found the switch :slight_smile:
got the same issue here…
Anybody can help us… or maybe developer can help… but muted.
Just like every other addon that supports ingress
But help why sometime open logs but sometime show only black screen.
