Home Assistant Community Add-on: motionEye
Correct, this is expected to be fixed in the next Hassio Supervisor release.
Iā€™m not sure what that means. My add-ons are build on native CPU services (e.g., the aarch64 add-on is build on a real aarch64/arm64 cpu/machine).
In the case of the aarch64 version of the add-on, the following package is installed by Alpine on installation of ffmpeg: https://pkgs.alpinelinux.org/package/v3.8/community/aarch64/ffmpeg
Interesting, does this mean we have a better way of implementing the Xiaomi dafang cameras into hass now, without the laggy rtsp stream?
TJ
Thanks @frenck, I was under the same impression but I canā€™t just manage to get LE running in my specific scenario. Would you mind taking a look at this old post of mine and let me know your thoughts on it? I used DuckDNS+Letā€™s Encrypt, but what I describe on it also applies to standalone LE add-on
I would appreciate it if you could point me in the right direction :slight_smile:
How du you add an normal USB camera hooked up to a pi and with HASSIO on it?
@Frenck: thanks for providing that add-on, really great work !
Is there a chance to get an HA event when a motion was detected (ideally with snapshot) ?
Iā€™m aware that motionEye has the the detection option but I donā€™t wanna use the mail notification.
Thereā€™s an option to send a webhook in motioneye. Just have it call a script
I have motionEye running on another raspberry pi in my system. I assume there is not way to point to that machine to implement the Add-on? Having said that the Hassio install appears to run on Alpine Linux platform that does not have apt-get or pip commands implemented to install motionEye. Any leads are most appreciated.
I canā€™t get this to run. What are the certfile and keyfile and where do I find them?
If you donā€™t have ssl set ssl to false and then youā€™re done.
Yes, thats what I did. But by the time the script is executed and a snapshot has been taken, the object triggering the motion event has passed :frowning:
I need the motion- event with the correlating when the event was triggered
Thank you teachingbirds, setting ssl to false has done it.
The motioneye is not coming up on the left panel though? I can open the ā€œWeb UIā€, which opens on the HASSio IP address so everything appearst to be workingā€¦ How do I get it do show in my left panel of HASS?
Try reading the manual :wink:
:man_facepalming: Ooops sorry my bad.
I saw that but thought it was for including each camera into the ā€œoverviewā€ tabs.
All working nowā€¦:blush:
it works perfect , thankyou!
i wasnt able to make the camera push to work ,
https://www.home-assistant.io/components/camera.push/
this is in order to be able to capture or show , pictures , when an 2interest" event occurs .
the pictures are captured , but the push camera is not working , no idea if is a HASS problem , or some limitation on the addon .
I have managed to find the RTSP URLā€™s for my two cameraā€™s which are XMEYE cameras.
rtsp://admin:@192.168.0.104/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp
rtsp://admin:@192.168.0.102/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp
I can successfully open these steams in VLC.
However when I try and enter the URL in motionEYE it does not work.
Screenshot%20from%202018-10-20%2002-27-32
In the log files it returns the error:
/bin/sh: lsb_release: not found WARNING: 403 GET /login/?_=1539998503606&username=&_signature=529b3bacb79d310e280c6fae96a1464b0adbe478 (127.0.0.1) 5.97ms Failed to open /dev/video0: No such file or directory
Any ideas please?
Iā€™ve done the same, remove at the beginning ā€œ admin:@ā€œ leaving only the ip , this is mine:
rtsp://192.168.1.10/user=admin_password=tlJwpbo6_channel=1_stream=1.sdp
@g.nigro Thank you very much! I would have never figured that out without your help.
:tada: Release v0.2.0
Full Changelog
Changed
  • Changed past to paste (#9) (@dayofdoom)
  • Change server name to avoid confusion (#4) (@timmo001)
  • Adds support for recording to Samba shares (#10)
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Thanks for this awesome addon!
Iā€™m trying to add a HLS Stream that is HTTPS and gets the error ā€œSSL certificate problem: unable to get local issuer certificateā€ in the Camera input.
I tried both Simple MJPEG Camera and Network camera. Any suggestions?
