Community Hass.io Add-on: MQTT Server & Web client
hassio-repository
hassio-addon
Tags: #<Tag:0x00007f1b9c2a7c68> #<Tag:0x00007f1b9c2a7ad8>
#21
Sorry I do not understand what that is … newb. Yes 1883 is the mqtt port, I do not know which websocket poert to use
#22
You need to check that on the broker you are using, look for ws or websocket.
if you are using the broker in this add-on the default ports for WS are 1884 (non-SSL) and 4884 (SSL)
#23
I see, I do use the mosquitto hassio addon
and this is the config,. I do not see anywhere mention of ws or websocket ports … ?
“plain”: true,
“plain_websockets”: false,
“ssl”: false,
“ssl_websockets”: false,
“anonymous”: true,
“logins”: [
“username”: “”,
“password”: “”
“customize”: {
“active”: true,
“folder”: “mosquitto”
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
#24
Look again :wink:
Both are disabled.
#25
thanks, I works now
#27
What would I use this for if I already use the standard broker? Is it just giving me information for troubleshooting? Something like MQTT.fx?
#28
Correct.
IMO the ACL configuration of this is easier (especially is you are not running custom hassio install)
#29
Not had a chance to try this yet but I suspect this is the biggest selling point. I have been swithering as to which platform to use to host my internal MQTT broker and this may just have swayed me :smile:.
#30
Addon appears to be running, but in chrome I see:
INFO: Starting mosquitto MQTT Server...
1538121720: mosquitto version 1.4.15 (build date 2018-03-04 15:35:59+0000) starting
1538121720: Config loaded from /opt/mosquitto.conf.
1538121720: Opening ipv4 listen socket on port 1883.
1538121720: Opening ipv6 listen socket on port 1883.
INFO: Starting NGINX for the MQTT client...
Config
  "log_level": "info",
  "certfile": "",
  "keyfile": "",
  "web": {
    "enabled": true,
    "username": "user",
    "password": "something",
    "ssl": false
  "broker": {
    "enabled": true,
    "enable_ws": false,
    "enable_mqtt": false,
    "enable_ws_ssl": false,
    "enable_mqtt_ssl": false,
    "allow_anonymous": true
  "mqttusers": [
      "username": "user",
      "password": "somethingelse",
      "readonly": false,
      "topics": [
#31
put http:// and not (it does automatically) https …?
#32
@Klagio yes that’s it! However now I get an error:undefined
Also tried 1883, in logs:
1538123520: Saving in-memory database to /data/mosquitto/mosquitto.db.
1538125321: Saving in-memory database to /data/mosquitto/mosquitto.db.
1538125774: New connection from 192.168.1.74 on port 1883.
1538125774: Socket error on client <unknown>, disconnecting.
#33
put this to true
#34
and / or try this to true
#35
"enable_ws": true fixes it, thanks @Klagio
#36
What is the benefit to running this addon only compared to running this alongside the mosquito addon?
Alongside, you will get a nice tool to inspect your topics and messages.
But remember to disable the broker in this (and change the ports)
#38
i just disabled the mosquito addon and commented out this from my config. None of my sonoff tasmota switches will now work. Any ideas?
I kept the user and password the same and subscribed to “#” topics. the ip and port are also the same.
 mqtt:
   broker: core-mosquitto
   username: ?
   password: ?
   client_id: ?
   discovery: true
   discovery_prefix: homeassistant
#39
well… if you no longer have mqtt: defined in your config, MQTT devices will no longer work.
#40
yeah i realised that and tried to reintroduce it into my config.yaml but now i get this.
2018-09-28 19:05:59 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=140 from 2018-09-28 17:58:33.998420)
2018-09-28 19:06:01 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno -2] Name does not resolve
2018-09-28 19:06:18 ERROR (MainThread) [homeassistant.setup] Setup failed for snips: Could not setup all dependencies.
2018-09-28 19:06:20 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.mqtt. Setup failed for dependencies: mqtt
2018-09-28 19:06:20 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.mqtt: Could not setup all dependencies.
#41
That also make sense since core-mosquitto (the mosquitto addon) now are disabled.
