No problem! Glad we figured it out.
Community Hass.io Add-on: Node-RED
Not sure why you are attacking my post?? I thought I was just +ing the issue since I am having it as well.
In any event I really appreciate your work - huge charitable contribution to the community.
Yes - I would love some help as I donât know where to start looking. My Node- Red install now cannot connect to Hass and I see the same in the Hass logs. This just started happening - could easily be a config error on my part but I, again, am not sure how to troubleshoot it.
Node-Red log (repeated many times):
26 Oct 15:50:50 - [error] [server:Home Assistant] Home assistant connection failed with error: Connection to home assistant could not be established with config: http://hassio/homeassistant
Hass supervisor log (also repeated many times):
18-10-26 22:51:47 WARNING (MainThread) [hassio.api.proxy] Unknown Home Assistant API access!
I had same problem so I try use http:// âipâ: âportâ e.g. http://192.168.1.200:8123 and it works now and after changing that restart nodeRED addon.
Update to this post. Uninstalled Node-Red (saved flows first!), SSHed into my HASSIO and deleted the Node-Red dir, reinstalled Node-Red, reloaded flows (using clipboard in case anybody is reading) and now it all works fine.
Guys. Help the rookie. Installed in ha Node-RED but it does not start at all (page not found) settings and logs:
Config:
âlog_levelâ: âinfoâ,
âcredential_secretâ: âJHhfdhiFRENCKfsdfdsDHFHDJSâ,
âusersâ: [
âusernameâ: âadminâ,
âpasswordâ: âvasyapupkinidiotâ,
âpermissionsâ: â*â
âhttp_nodeâ: {
âhttp_staticâ: {
âportâ: 1880,
âsslâ: false,
âcertfileâ: âfullchain.pemâ,
âkeyfileâ: âprivkey.pemâ,
ârequire_sslâ: true,
âsystem_packagesâ: [],
ânpm_packagesâ: [],
âinit_commandsâ: []
log:
[s6-init] making user provided files available at /var/run/s6/etcâŚexited 0.
[s6-init] ensuring user provided files have correct permsâŚexited 0.
[fix-attrs.d] applying ownership & permissions fixesâŚ
[fix-attrs.d] done.
[cont-init.d] executing container initialization scriptsâŚ
[cont-init.d] 00-banner.sh: executingâŚ
Hass.io Add-on: Node-RED v0.7.0
Flow-based programming for the Internet of Things
By: Franck Nijhof [email protected]amd64 / Ubuntu 18.04.1 LTS / HA 0.81.0 / SU 138 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executingâŚ
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executingâŚINFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-requirements.sh: executingâŚ
INFO: Password is NOT in the Have I Been Pwned database! Nice!
Yeah, thatâs not really a fix but more of a workaround. It shouldnât be necessary though.
There are at least three options based on the very limited info you provided:
you are accessing HA via DuckDNS or similar and clicked the âOpen web UIâ-button,
while the port is not forwarded/accessible using that url -
you didnât post the full log and there is an error somewhere further
the add-on simply is not started up yet, as there is a lot missing in the log you provided,
below you can find an example of what should follow after yours
and the last line clearly stating it started up
[cont-init.d] 10-requirements.sh: exited 0.
[cont-init.d] 11-warning.sh: executing...
[cont-init.d] 11-warning.sh: exited 0.
[cont-init.d] 20-config.sh: executing...
[cont-init.d] 20-config.sh: exited 0.
[cont-init.d] 30-auto-api-token.sh: executing...
INFO: API token is incorrect in the Node-RED configuration, fixing...
[cont-init.d] 30-auto-api-token.sh: exited 0.
[cont-init.d] 80-system-packages.sh: executing...
[cont-init.d] 80-system-packages.sh: exited 0.
[cont-init.d] 81-npm-packages.sh: executing...
[cont-init.d] 81-npm-packages.sh: exited 0.
[cont-init.d] 82-user-scripts.sh: executing...
[cont-init.d] 82-user-scripts.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
> [email protected] start /opt
> node $NODE_OPTIONS node_modules/node-red/red.js "--settings" "/etc/node-red/config.js"
28 Oct 15:27:41 - [info]
Welcome to Node-RED
28 Oct 15:27:41 - [info] Node-RED version: v0.19.4
28 Oct 15:27:41 - [info] Node.js version: v8.11.4
28 Oct 15:27:41 - [info] Linux 4.14.66-v7 arm LE
28 Oct 15:27:45 - [info] Loading palette nodes
28 Oct 15:28:08 - [info] Settings file : /etc/node-red/config.js
28 Oct 15:28:08 - [info] Context store : 'default' [module=memory]
28 Oct 15:28:08 - [info] User directory : /config/node-red/
28 Oct 15:28:08 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 Oct 15:28:08 - [info] Flows file : /config/node-red/flows.json
28 Oct 15:28:08 - [info] Starting flows
28 Oct 15:28:08 - [info] Started flows
28 Oct 15:28:09 - [info] Server now running at http://127.0.0.1:1880/
Release v1.0.0
It contains breaking changes! So please read this carefully!
This is a BIG release, and that is why I marked this release v1.0.0!
The Home Assistant connector node has been replaced by node-red-contrib-home-assistant-websocket
and uses WebSockets to connect to Home Assistant, which is actually the preferred method to use when talking to Home Assistant. It improves reaction speed and is build on top of the official Home Assistant WebSocket libraries.
The add-on now handles Home Assistant restarts automatically. You no longer need custom flows or restart magic to fix Node-RED after Home Assistant restarts .
Furthermore, authentication has been replaced. Node-RED now authenticates users against Home Assistant . This allows you to log into your Node-RED using your Home Assistant credentials.
Some other noteworthy changes:
http_node
no longer requires a username/password and can be left empty if youâd like. -
http_static
no longer requires a username/password and can be left empty if youâd like. - The Google TTS API should be fixed (love to hear feedback on this!).
- The add-on has now âManagerâ access to the Hass.io API, which allows you to restart Home Assistant and Hass.io add-ons in your flows.
- The documentation has been updated with an FAQ to help with common problems.
Upgrade instructions
- Be sure to run at least Home Assistant
0.80.1
. Any older version might cause troubles with getting connected or on logging in. - Remove the
users
list from the add-on configuration. You donât need it anymore since the add-on now authenticates against Home Assistant. - There are some breaking changes with two of the nodes. The
Poll State
andCurrent State
both have a little different formatted output. Check your nodes and make sure they are outputting what you expect. - If you have been using the
@Spartan-II-117
fork, this upgrade should be a drop in replacement. It is strongly suggested to not use this fork with this add-on anymore. - Finally, make sure your Home Assistant server connection in Node-RED uses
as the server URLThis is really important, you really donât need any other URL or long lived access token.
Changed
- Fix typo in README (#40) (@zpartal)
- Upgrades node-red-contrib-influxdb to version 0.2.2 (#41)
- Upgrades gcc to 6.4.0-r9
- Upgrades nodejs to 8.12.0-r0
- Switches add-on to node-red-contrib-home-assistant-websocket
- Forcing broken world to enable latest NodeJS
- Removes node-red-contrib-change-detect (#48) (@bonanitech)
- Adds HA Authentication to Node-RED (#52)
- Renames authentication config option (#53)
- Updates node-red-contrib-moment to version 3.0.1 (#63)
- Upgrades git to 2.18.1-r0
- Updates node-red-contrib-actionflows to version 2.0.1 (#65)
- Upgrades google-tts-api to 0.0.3 (#61) (@heytcass)
- Fixes incorrect JSON formatting in package.json
- Removes unneeded warning about no users
- Removes Auto API token script, not needed anymore
- Removes requirement for setting http node/static credential
- Adds possibility to disable HA Authentication
- Updates the README to reflect the latest changes
- Up the security level of the Hassio API to manager
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
Login failed to Node-RED
User authentication
Wow thanks! When will this be available? Hassio still shows 0.70 wand still doesnât detect the new version.
It is available already. If it doesnât show up, you can force the update by going into the add-on store and hit the reload button in the top right. The update should popup a couple of seconds after that.
Thank you that did it.
Node-red autoconnect on HA restart works beautifully! I can see that the green âconnectedâ indicator below the HA nodes will keep flashing red-yellow-green until HA comes back up.
Node-Red just updated to v1.0 but I can no longer log in to the system. I tried pasting my password in directly from the config but no luck.
I have now removed my username and password from the config entirely, rebooted both Node-Red and Hass.io but I am still greeted by the login page when accessing Node-Red. Pressing submit with no entry or a space in each results in âlogin failedâ.
Is there some kind of default username and password I am missing? I donât understand why it wonât let me log in. I have reset the Config to defaults with the exception of all my SSL being false (Iâm not exposing this page publicly) and my credential_secret being completed.
Any help is appreciated, my initial log is below but there are no errors (apart from one Node-red tried to connect to home assistant after the last line I paste here, but I feel that is a separate issue which I can look into once I can log into the system!)
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Node-RED v1.0.0
By: Franck Nijhof <[email protected]>
amd64 / Ubuntu 18.04.1 LTS / HA 0.81.1 / SU 138 / stable
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 02-updates.sh: executing...
[cont-init.d] 10-requirements.sh: executing...
[cont-init.d] done.
[services.d] done.
30 Oct 07:34:07 - [info]
Welcome to Node-RED
Thanks!
After update i can no longer log in to noderedâŚ
Tried changing admin user and pass to the same as hass but cant log in.
I hav hassio with z-wave on one pi and hassio with nodered on a different pi
Remove the users
were you able to resolve this issue?
I removed users
and username, password
and I even changed hass.io
paassword in case I have it wrongâŚ
Thank you.
thanx @jpm. I removed it and logged in with my hass user⌠Then i created a long lived token to use to connect to hassio and that worked
Please donât use the long lived access tokens! Please, take the time to read the upgrade instructions. You donât need them! Secondly, the method provided by the add-on (without access token) adds more security as well.
So for the love of god, please stop posting this as an answer, since it isnât.
