Home Assistant Community Add-on: Pi-hole
Only other thing is DuckDNS - would that be the problem?
Could be, just check what Port it is using. And then maybe change 53 to 54 or anything else thats not used up.
Any plans to update this add on to v4? Ta
I’ve already started on the upgrade the day it came out, not sure about an ETA. Changes to v4 are pretty big.
Curious what others think to the performance overhead of this on a Pi3? I already have HassIO and about to install the UniFi controller and piHole. DOn’t want to overload my little Pi :slight_smile:
The current Pi-hole is pretty low on resource consumption. Furthermore, v4, will be consuming less. Nevertheless, I all depends on a lot of factors. E.g., automations and components used e.d…
I don’t expect any problems. I’ve only been running it on a Pi3 for a few days, but I’ve run it for months on a Pi2 previously. I haven’t used the UniFi controller, but when I first installed Pi-hole, there wasn’t a discernible performance hit.
Hey guys… a little help, please.
I’m running HassOS on a static IP, and DNS servers pointing to google. My Pi-hole is up and running and I have both DNS and DHCP enabled, but somehow I still can’t access HA using my DuckDNS domain. I thought once I set the static IP to the RPi3 this would be solved, but that’s not the case.
How can I solve this?
Thanks in advance.
Many thanks for this add-on, working great when I use my default dns settings on my mac. I use a smart dns proxy to bypass geo-restrictions, I’ve tried adding the relevant dns address to the upstream settings in the pi-hole web interface but this doesn’t work. Any pointers for what I need to do?
What version of Pi-hole is used??
The current stable version for the add-on is Pi-hole v3.3.1, Pi-hole v4 is currently under development.
At the moment it uses the latest Pi-hole core v3, so that’s 3.3.1
Dashboard v3.3 and FTL engine v3.0, the more you know.
V4 of Pi-hole is currently under development to work as a Hass.io add-on.
Edit: seems like Franck beat me to it :exploding_head:
Thanks, then I wait for that version. The Pi-hole is very different in v.4
Well, it’s not that different. You could easily install it now and just update later.
The add-on will provide a single click upgrade path @Yuran
OK thank you
I need a bit of help, I am new to Hassio but slowly getting things done. WAF is going up as well, so I reckon I am on good tuck. But bragging aside I have installed PiHole, it is working as expected (but still android phone YouTube is getting ads sometimes), I have a few list and suddenly I can’t open two sides: aliexpess and gearbest. I tried to add this to whitelist but no luck, I got DNSthingy addon to Chrome but probably do not know which kind of information to look for. Can anybody help me please?
Cheers
Recently, I started exploring more advaced things that I can do with HA and I stumble across Pi Hole. I have installed latest addon (1.3) and confirgured it to best of knowledge as below. When In click open wed interface I get below UI and I am not sure what username / password to use there. Any comments / feedback highly appriciated.
My addon configuration is listed below along with logs that I get when I start the addon.
Configuration
  "log_level": "info",
  "password": "password",
  "update_lists_on_start": true,
  "http_port": 80,
  "https_port": 443,
  "dns_port": 53,
  "ssl": false,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "interface": "",
  "ipv6": true,
  "ipv4_address": "",
  "ipv6_address": "",
  "virtual_host": "https://xxxxx.duckdns.org:8123/",
  "hosts": []
Logs on start up
 Hass.io Add-on: Pi-hole v1.3.0
 Network-wide ad blocking using your Hass.io instance
 By: Franck Nijhof <[email protected]>
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing...
[cont-init.d] 10-requirements.sh: exited 0.
[cont-init.d] 11-patches.sh: executing...
[cont-init.d] 11-patches.sh: exited 0.
[cont-init.d] 11-pihole.sh: executing...
[cont-init.d] 11-pihole.sh: exited 0.
[cont-init.d] 12-dnsmasq.sh: executing...
[cont-init.d] 12-dnsmasq.sh: exited 0.
[cont-init.d] 13-nginx.sh: executing...
[cont-init.d] 13-nginx.sh: exited 0.
[cont-init.d] 14-password.sh: executing...
  [✓] New password set
[cont-init.d] 14-password.sh: exited 0.
[cont-init.d] 15-hostname.sh: executing...
[cont-init.d] 15-hostname.sh: exited 0.
[cont-init.d] 16-logfiles.sh: executing...
[cont-init.d] 16-logfiles.sh: exited 0.
[cont-init.d] 17-hosts.sh: executing...
[cont-init.d] 17-hosts.sh: exited 0.
[cont-init.d] 50-gravity.sh: executing...
  [i] Neutrino emissions detected...
  [i] Pulling blocklist source list into range...
  [✓] Pulling blocklist source list into range
  [i] Target: raw.githubusercontent.com (hosts)
  [i] Status: Pending...
  [✓] Status: Retrieval successful
  [i] Target: mirror1.malwaredomains.com (justdomains)
  [✓] Status: No changes detected
  [i] Target: sysctl.org (hosts)
  [i] Target: zeustracker.abuse.ch (blocklist.php?download=domainblocklist)
  [i] Target: s3.amazonaws.com (simple_tracking.txt)
  [i] Target: s3.amazonaws.com (simple_ad.txt)
  [i] Target: hosts-file.net (ad_servers.txt)
  [i] Consolidating blocklists...
  [✓] Consolidating blocklists
  [i] Extracting domains from blocklists...
  [✓] Extracting domains from blocklists
  [i] Number of domains being pulled in by gravity: 159002
  [i] Removing duplicate domains...
  [✓] Removing duplicate domains
  [i] Number of unique domains trapped in the Event Horizon: 135752
  [i] Nothing to whitelist!
  [i] Parsing domains into hosts format...
  [✓] Parsing domains into hosts format
  [i] Cleaning up stray matter...
  [✓] Cleaning up stray matter
  [✗] dnsmasq: no process found
pihole-FTL: no process found
  [✓] DNS service is running
  [✓] Pi-hole blocking is Enabled
[cont-init.d] 50-gravity.sh: exited 0.
[cont-init.d] 99-tests.sh: executing...
dnsmasq: syntax check OK.
[21-Aug-2018 23:52:25] NOTICE: configuration file /etc/php7/php-fpm.conf test is successful
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
[cont-init.d] 99-tests.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Did you forward port 80?
Otherwise I would guess this is not Pi-hole you’re accessing, but your router/modem.
Try using http://YOUR_PI_IP_ADDRESS/admin/.
:tada: Release v2.0.0
This is a big/major release and upgrades Pi-hole to v4.0!
:warning: Breaking changes
There are some changes that from the 1.x series of the add-on.
  • Pi-hole now uses NULL based routing, the “Blocked” page is therefore no longer needed/available.
  • http_port and https_port have been replaced with admin_port.
  • The default port for the admin interface is now: 4865
  • SSL is now enabled by default, you need to disable it manually in case you don’t use SSL.
  • Setting as password for authentication is now enforced.
Full Changelog
Added
  • Pi-Hole FTL v4.0 patches
  • Adds default block list
  • Adds Pihole FTL config
  • Adds default DNSMasq configuration
  • Adds Pihole vX -> v4 migration script
  • Adds admin port support to NGinx
Fixed
  • Fixes reloading of DNS on white/blacklist changes (#33)
  • Patches pihole-FTL.conf to not break the admin interface
Changed
  • Upgrades base image to v2.1.2
  • Sets default Shell
  • Enforces authentication and HaveIBeenPwned checks
  • Updates README and links
  • Upgrades OpenSSL to 1.0.2o-r2
  • Upgrades PHP to 7.2.8-r1
  • Enables SSL by default
  • Upgrades ncurses to 6.1_p20180818-r0
  • Replaces dnsmasq with pihole-FTL
  • DNS container init move and migration
  • Changes order of container init
  • Updated forum link
  • Updates README to match recent changes
Removed
  • Removes DNSMasq
  • Removes Pihole Block page, moving to NULL based blocking
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
