Home Assistant Community Add-on: Tor
I also seem to be having the same problem with the Tor add-on.
Hi, need some help with this any suggestions?pls.this is my config;
  "log_level": "info",
  "socks": true,
  "hidden_services": true,
  "stealth": true,
  "client_names": [
    "haremote1"
  "ports": [
    "homeassistant:8123:80"
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 10-tor: applying...
[fix-attrs.d] 10-tor: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: Tor v1.6.1
 Protect your privacy and access Home Assistant via Tor.
 By: Franck Nijhof <[email protected]>
 aarch64 / HassOS 2.10 / HA 0.88.1 / SU 145 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing...
[cont-init.d] 10-requirements.sh: exited 0.
[cont-init.d] 20-dirs.sh: executing...
[cont-init.d] 20-dirs.sh: exited 0.
[cont-init.d] 50-tor-log.sh: executing...
[cont-init.d] 50-tor-log.sh: exited 0.
[cont-init.d] 51-tor-socks.sh: executing...
[cont-init.d] 51-tor-socks.sh: exited 0.
[cont-init.d] 52-tor-services.sh: executing...
[cont-init.d] 52-tor-services.sh: exited 0.
[cont-init.d] 90-hostname.sh: executing...
INFO: -----------------------------------------------------------
INFO: Your Home Assistant instance is available on Tor!
INFO: Addresses & Auth cookies:
INFO: xxxxxxxxxxxxxxxb.onion gxxxxxxxxxxxxxxR # client: haremote1
[cont-init.d] 90-hostname.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Feb 26 16:50:46.149 [notice] Tor 0.3.3.7 (git-035a35178c92da94) running on Linux with Libevent 2.1.8-stable, OpenSSL LibreSSL 2.7.4, Zlib 1.2.11, Liblzma N/A, and Libzstd N/A.
Feb 26 16:50:46.149 [notice] Tor can't help you if you use it wrong! Learn how to be safe at https://www.torproject.org/download/download#warning
Feb 26 16:50:46.149 [notice] Read configuration file "/etc/tor/torrc".
Feb 26 16:50:46.169 [notice] Scheduler type KIST has been enabled.
Feb 26 16:50:46.169 [warn] You specified a public address '0.0.0.0:9050' for SocksPort. Other people on the Internet might find your computer and use it as an open proxy. Please don't allow this unless you have a good reason.
Feb 26 16:50:46.169 [notice] Opening Socks listener on 0.0.0.0:9050
Feb 26 16:50:46.000 [notice] Parsing GEOIP IPv4 file /usr/share/tor/geoip.
Feb 26 16:50:47.000 [notice] Parsing GEOIP IPv6 file /usr/share/tor/geoip6.
Feb 26 16:50:47.000 [warn] You are running Tor as root. You don't need to, and you probably shouldn't.
Feb 26 16:50:47.000 [notice] We were built to run on a 64-bit CPU, with OpenSSL 1.0.1 or later, but with a version of OpenSSL that apparently lacks accelerated support for the NIST P-224 and P-256 groups. Building openssl with such support (using the enable-ec_nistp_64_gcc_128 option when configuring it) would make ECDH much faster.
Feb 26 16:50:49.000 [notice] Bootstrapped 0%: Starting
Feb 26 16:50:52.000 [notice] Starting with guard context "default"
Feb 26 16:50:52.000 [notice] Bootstrapped 80%: Connecting to the Tor network
Feb 26 16:50:53.000 [notice] Bootstrapped 85%: Finishing handshake with first hop
Feb 26 16:50:54.000 [notice] Bootstrapped 90%: Establishing a Tor circuit
Feb 26 16:50:54.000 [notice] Tor has successfully opened a circuit. Looks like client functionality is working.
Feb 26 16:50:54.000 [notice] Bootstrapped 100%: Done
HOME ASSISTANT LOG
2019-02-26 18:09:12 ERROR (MainThread) [homeassistant.components.http.data_validator] Data does not match schema: required key not provided @ data['client_id']
Just adding a +1 to having this error. After trying loads of different settings, with stealthmode off I eventually entered ā€œ192.168.1.1:8123:8080ā€ in the ports option and it started working!..and then upon logging in gave me the same error as Andy_Nunes. There is a rather bizarre disconnect between the instructions and reality for Tor noobs like myself. Once this finally works Iā€™ll post the instructions that actually worked for me.
:grinning: TOR is now working with the latest update 89.0 :+1:t3:
Special thanks to all the guys behind the scenes :blush:
:tada: Release v2.0.0
Full Changelog
Changes
  • :arrow_up: Upgrades add-on base image to 3.0.1
  • :arrow_up: Upgrades tor to 0.3.4.11-r0
  • :sparkles: Adds support for ARMv7
  • :fire: Removes custom log format override
  • :hammer: Makes log_level optional
  • :books: Updates documentation for ARMv7
  • :hammer: Rewrite add-on onto Bashio
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
I just updated to V2.0.0, but the addon wonā€™t start if configured in stealth mode. In the previous version this worked without problems.
Hereā€™s my config:
  "socks": false,
  "stealth": true,
  "client_names": [
    "name123"
  "ports": [
    "8123"
When stealth is false, the addon starts as expected.
Any suggestions what I am doing wrong?
Thx Luke
Log:
[fix-attrs.d] done.
 Hass.io Add-on: Tor
 Add-on version: 2.0.0
 You are running the latest version of this add-on.
 System: HassOS 2.11  (armv7 / raspberrypi3)
 Home Assistant version: 0.90.1
 Supervisor version: 150
 Please, share the above information when looking for help
 or support in e.g, GitHub, forums or the Discord chat.
[14:00:34] INFO: Starting Tor temporarly...
[cont-init.d] 90-hostname.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
same here, issue opened :\
Is there an estimated date for when the fix for this issue will be published on the release version of this add-on? (I saw it was fixed already on a beta version or so)
the only thing they said was basically ā€œwaitā€ā€¦ which is really sad considering the situation, but there we are :\
It is not. That is the issue.
If that fixed it, I would have released it already.
I donā€™t have that. This is an open source project, which relies on my own spare free time that I can donate to the project OR contributors.
Feel free to contribute a proper fix is you have one. Iā€™m happy to merge and release.
Hi @frenck, reading the comments on this thread I got the impression it was solved but not merged to the release version. Apparently I was mistaken and I apologize.
Iā€™m fully aware of this project being an open source and specifically to your amazing contribution to it and other projects. I wish I could help but it is a bit above my pay grade :wink:
Anyway, now it is clear the issue is still pendingā€¦
Cheers.
Dear @frenck , Maybe it is possible to return the previous version, in which everything worked?
Nope, that is not possible.
Did the latest update (0.96 and 0.96.1) break the Tor add-on? Since the update I canā€™t get to a login page using Tor. It connects, then loads the blue background across the top, and the white background. View-source shows some html and loaded js, but I canā€™t actually get the ui to load. I can connect at home without Tor.
Iā€™ve tried restarting the add-on and restarting my raspi.
The latest version is 2.0.0 and it does not work if stealth mode enabled. but does work without it.
The previous version (donā€™t remember exact number) worked fine for me in both modes.
Thanks for the reply. Iā€™m using version 2.0.0 of the Tor add-on without stealth enabled. It worked great until Home Assistant version 0.9.6. It connects, but nothing but the background appears.
Mine works. Open a new issue on Github if yours doesnā€™tā€¦
Hallo HA fans;
Same here with HassIO, 96.3 and 2.0.0.
First I used orbot and orfox and now single tor browser. Connection is much quicker and smoother but only a white HA background with empty blue top banner are shown. The HA-tor add-on log confirms connection!
It appears that the torrc file has been seen and taken bby Tor Browser from Otbot nnow uninstalled, is that a correct assumption?
Thanks in advance
Martin J
:tada: Release v2.1.0
Full Changelog
Changes
  • :ambulance: Fixes client definitions for stealth mode (#13)
  • :ambulance: Fixes client names when in stealth mode
  • :ambulance: Sets missing HiddenServicesVersion
  • :ambulance: Fixes incorrect torrc configuration
  • :pencil2: Maintaince -> Maintenance
  • :arrow_up: Upgrades add-on base image to v4.1.1
  • :arrow_up: Upgrades tor to 0.3.5.8-r0
  • :books: fixed client_names (#14)
