The 22nd edition of the Home Assistant Community Highlights! Some interesting things popped up around our community, we thought was worth sharing.
Do you want to share something for the next edition? Information on how to share.
./Klaas Intern on Home Assistant Energy
Blueprint of the week
Are you one of those who always leave the doors open?
Then this week we have a nice blueprint for you! BasTijs has made a blueprint that announces through text to speech in the house, that a door is open and only stops when the door is closed again.
Try it out! Read more about it on the community forum or install this automation in your instance with a click on the My button!
Sun card
On our Home Assistant reddit page we also encountered another nice project, namely that of AitorDB. Who made a Lovelace card that shows the position of the sun when it rises, is at its highest point and sets again.
Collapsed card
Is your Lovelace dashboard overflowing with cards and do you want to make some free space? Then try the card made by RossMcMillan92, which makes it possible to collapse entire cards and reappear as a dropdown.
Hyperion - HA bridge
You have those TVs where LEDs are mounted on the back so that the colors of the TV continue over the wall behind it, this is also called ambilight. If your TV is not equipped with this, you can also make this yourself through the Hyperion project. pimw has also written an instruction post about this on our community forum on how to connect the bridge to Home Assistant.
Got a tip for the next edition?
Have you seen (or made) something awesome, interesting, unique, amazing, inspirational, unusual or funny, using Home Assistant?
Click here to send us your Community Highlight suggestion.
Also, don’t forget to share your creations with us via Social Media:
See you next edition!
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2021/05/21/community-highlights/
