Home Assistant Community
Compact Custom Header
#409
Nevermind, I’m an idiot. I had changed my config to enable CCH and forgot to push it to my github. Blame lack of sleep for this one, thanks for all the help and supporting this awesome component.
#410
Update 1.0.1b1:
Added a date option to add a date above the clock, tweaked caching a bit, and adjusted a few styles for notification indicator and the editor.
#411
I’ve just installed this for the first time today, I have the latest version, and it’s all working except the clock - I’m trying to replace the voice icon with the clock, but I’m obviously misunderstanding something. I’m running Hassio on an RPi, HA version 87.1. I don’t use the custom updater. My config looks like this:
  - id: 0  # Automatically created id
    title: default_view
    theme: greypaper
    icon: mdi:home
    cards:
      - type: custom:compact-custom-header
        main_config: true
        background_image: true
        options: show
        voice: clock
        notifications: show
And the right side of my header looks like this:
header
There are no errors in my log. What I am doing wrong? Thanks for any help.
#412
What browser are you using and is the voice icon there when not using compact-custom-header?
#413
Sorry, should have said, Chrome on a Windows PC. The voice icon was there before I installed compact-custom-header, and missing afterward. I’ve just commented all compact-custom-header code out of my ui-lovelace.yaml file and reloaded Lovelace and ctrl-F5’d, and the voice icon did not come back. Not sure if I have to restart HA…
#414
Double check that conversation: is in your configuration.yaml
#415
Bingo! It was commented out (has been for a long time). I put it back, restarted HA without compact-custom-header, and the voice icon came back. I put the compact-custom-header code back in and now it’s working as expected - voice icon replaced by clock. Thanks so much for your help! I would not have figured that out on my own.
#416
I know I’m missing it somewhere in these posts, but how do I “turn off” the header if I’ve made a mistake. I updated and have cleared errors, but now cannot get into the lovelace configuration, to edit or raw. The options are missing. The compact header is mostly working other than I can no longer make any changes to anything. :slight_smile:
#417
Check the “important notes” section of the readme. First item.
Just wanted to say big thanks. Works great on my old iOS10 iPad, and I can create a view with only cards that work and filter that using the compact header component. <3
:+1:
I’m glad to hear it’s working for others as well.
#420
Hi I’m using HomeAssistant 0.88.1 and using the latest compact custom header 1.0.1b2, I keep getting a service log error:
/compact-custom-header-editor.js?v=1.0.1b2:35:1 Uncaught SyntaxError: Unexpected token export
#421
Since 0.89.0b0 i’m seeing a big gap between the tabs and the cards.
Auswahl_180
@mayker, could this be an issue with your card?
#422
make sure you have javascript_version: latest in your configuration.yaml under frontend:
#423
Will check this out as soon as I can get on 0.89.0b0
#424
Thanks!
When i right click the gap and inspect, it disappears, but what i see in the inspector is chinese for me. :neutral_face:
#425
Alright, on 0.89.0b0 now. Not seeing that behavior on my end. Could you share your config for the card and also verify that this doesn’t happen when removing (commenting out) CCH?
#426
When i’m commenting out the CCH, all looks normal and i have the big header.
Now i found that views in panel mode and @thomasloven 's layout-card have no gap between the tabs and the cards.
Auswahl_182 Auswahl_181
Maybe the issue is here?
Thanks for looking at it!
#427
thanks for that,
I followed: https://www.home-assistant.io/components/frontend/
frontend:
I’m still getting the service log error tho
#428
Did it ever work @gekim.84?
