@VDRainer Could you share your config for the card?
@gekim.84 What browser are you using?
@ludeeus
yes the compact header works, i just get this pop-up every time i load/ refresh at the bottom left corner saying
@mayker
I’m using Chrome (latest version)
- type: custom:compact-custom-header
menu: overflow
background_image: true
exceptions:
- conditions:
user_agent: Mobile
config:
options: hide
hide_tabs: 13,14,15,16,17
- conditions:
user: TPad
config:
menu: hide
options: hide
hide_tabs: 0,1,2,3,4,5,6,7,8,9,10,11,12
That pop-up is telling you that an error was written to the log. Click the info icon (far right) under developer tools in your sidebar to see what the error is. Or is it just the export error? Sorry if I’m telling you something you already know.
Does removing background_image: true
“fix” the issue?
Unfortunately no,
yes its just the export error, the compact header works tho.
here’s that full log error again (my url removed):
https://[myurl]/local/custom-lovelace/compact-custom-header-editor.js?v=1.0.1b2:35:1 Uncaught SyntaxError: Unexpected token export
Service system_log/write called.
Okay, think I’ve been able to reproduce this. Check your browser dev-tools errors (F12), I imagine you’re getting something like TypeError: Cannot read property 'querySelector' of null
around line 355.
This will require an update, but I’m on it.
The menu button elements changed a bit in HA 0.89.0b0. This is fixed in the latest version 1.0.1b3.
The latest update only addressed the HA 0.890b0 issues. Please, share your resources section and config for this card. Are you using YAML or storage mode? Have you restarted after adding javascript_version: latest
? Have you cleared your cache?
ahhh I see,
I’m on Synology Docker
HA 0.88.1
using yaml
I’ve homeassistant.restart everytime
I’m using latest chrome browser, clear cache as well
this is my resources:
- url: /local/custom-lovelace/compact-custom-header.js?v=1.0.1b3 type: module - url: /local/custom-lovelace/compact-custom-header-editor.js?v=1.0.1b3 type: js
#MY DASHBOARD
- title: Main Dashboard
icon: mdi:home
panel: true
cards:
- type: custom:layout-card
layout: vertical
cards:
- type: custom:compact-custom-header #Custom Compact Header
main_config: true
menu: show
options: clock
voice: hide
notifications: hide
clock_format: 12
Remove the editor portion from your resources completely. Editors do not need added there, just the cards. Remove these 2 lines:
type: js
I see, thank you, beginner here and I didn’t know about that.
removed and fixed
Love the clean look of this, but I’ve set notifications as overflow
and the badge doesn’t display correct
That might be an issue with your theme?
I suspected this, but it looks like this even with the default theme
Looks like I just need to adjust the styling of the indicator when it’s in there. Will fix soon.
Great. Thanks!
Look forward to it!
Do you need a big reported in git hub?
