Compare actual values and setpoints of several thermostats
Hello, I have seven thermostats. Now I would like to compare the actual value and the setpoint of all thermostats. If the setpoint is too low for a thermostat, the heating pump should be switched on. If the values ​​are correct, the heating pump should be switched off again. After being a total newbie, I would like to have one or more hints on how to do this
thx
Does not anyone have an idea? I do not need a complete solution, just a rough direction. Do I only use automation or do I need scripts or something else? I’m grateful for any hint
@juhuu - take a look at the following files on my GitHub repository.
Probably not an exact solution, but it will help you understand how I set up two thermostats for full automation. Hope it helps.
kartcon
thx :+1:
I’ll take a closer look
