I have some esphome code that dumps the output of an rs232 module to the debug log.
Now I would like to compare the output line to a string so I can do something with it.
My problem is that I don’t understand how to convert UARTDebug::log_string(direction, bytes)
to a string that works with strcmp.
Can anyone help?
uart:
baud_rate: 9600
tx_pin: 17
rx_pin: 16
stop_bits: 1
data_bits: 8
parity: NONE
debug:
direction: RX
dummy_receiver: true
after:
delimiter: ";78H\e[m"
#delimiter: "\n"
#bytes: 98
sequence:
lambda: !lambda |-
UARTDebug::log_string(direction, bytes); // prints out the data recived from the rs232 port
// I think I need to convert the " void esphome::uart::UARTDebug::log_string ( UARTDirection direction,std::vector< uint8_t > bytes ) " to a regualr string for comparision ?
// This does not work (or compile)
if (strcmp((UARTDebug::log_string(direction, bytes)), "banana")) {
ESP_LOGD("Found banana, do something here");
