Compatible wall outlets with USB (no smart plugs)
Hi everyone!
This is my first post so if anything is mistaken here, my apologies in advance :pray:t2:
So, I want to buy some wall outlets but I want them to have USB ports.
This is one example:
About the title, I’m not talking about smart plugs (the ones that you connect to a wall outlet) for example:
To recap, I’m not looking for the devices on the second list. Sadly, most of the info I’ve found points to this kind of devices
I mainly want the devices on the first list but I haven’t found a compatible one with USB ports.
I also have seen there some products which include power monitoring but that is not a requirement for me.
However, there 2 important requirements:
  • Timers: for example (turning the outlet off from 00:00 to 08:00 and, turning it on from 08:00 to 23:59)
  • Independent outlet management: what I mean by this is managing each outlet (top & bottom) independently. If I set a timer, it should be set only to the top/bottom one. Also, turning on/off only one of them instead of the whole unit
If you know a device with these features & is compatible with HA, please let me know.
Thank you so much!
