Does anyone know where there might be some documentation about the files that are produced when compiling ESPhome locally using Python, ie what files to upload using the web browser?
$ esphome compile pana-hz25tke-230521.yaml
./.esphome/build/pana-hz25tke/.pioenvs/pana-hz25tke/bootloader.bin
./.esphome/build/pana-hz25tke/.pioenvs/pana-hz25tke/firmware-factory.bin
./.esphome/build/pana-hz25tke/.pioenvs/pana-hz25tke/firmware.bin
./.esphome/build/pana-hz25tke/.pioenvs/pana-hz25tke/partitions.bin
This is the complete output:
Summary
ESPHome 2023.5.4
INFO Reading configuration pana-hz25tke-230521.yaml...
INFO Cloning https://github.com/DomiStyle/[email protected]
INFO Generating C++ source...
INFO Core config or version changed, cleaning build files...
INFO Compiling app...
If you like PlatformIO, please:
- follow us on Twitter to stay up-to-date on the latest project news > https://twitter.com/PlatformIO_Org
- star it on GitHub > https://github.com/platformio/platformio
- try PlatformIO IDE for embedded development > https://platformio.org/platformio-ide
Processing pana-hz25tke (board: mhetesp32minikit; framework: arduino; platform: platformio/[email protected])
Platform Manager: Installing platformio/espressif32 @ 5.3.0
INFO Installing platformio/espressif32 @ 5.3.0
Downloading [####################################] 100%
Unpacking [####################################] 100%
Platform Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Tool Manager: Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
INFO Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Tool Manager: [email protected]+2021r2-patch5 has been installed!
INFO [email protected]+2021r2-patch5 has been installed!
Tool Manager: Installing platformio/framework-arduinoespressif32 @ ~3.20005.0
INFO Installing platformio/framework-arduinoespressif32 @ ~3.20005.0
Tool Manager: [email protected] has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.40400.0
INFO Installing platformio/tool-esptoolpy @ ~1.40400.0
Library Manager: Installing esphome/AsyncTCP-esphome @ 1.2.2
INFO Installing esphome/AsyncTCP-esphome @ 1.2.2
Library Manager: [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing bblanchon/ArduinoJson @ 6.18.5
INFO Installing bblanchon/ArduinoJson @ 6.18.5
Tool Manager: Installing platformio/tool-scons @ ~4.40400.0
INFO Installing platformio/tool-scons @ ~4.40400.0
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 1.2.2
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- ArduinoJson @ 6.18.5
Compiling .pioenvs/pana-hz25tke/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/climate/climate.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/climate/climate_mode.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/climate/climate_traits.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/dallas/dallas_component.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/dallas/esp_one_wire.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/json/json_util.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/ota/ota_component.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/panasonic_ac/esppac.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/panasonic_ac/esppac_cnt.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/panasonic_ac/esppac_wlan.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/restart/switch/restart_switch.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/select/select.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/select/select_call.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/select/select_traits.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/sensor/automation.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/sensor/filter.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/sensor/sensor.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/status_led/status_led.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/switch/automation.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/switch/switch.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/uart/uart.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/uart/uart_component.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/uart/uart_component_esp32_arduino.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/uart/uart_component_esp8266.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/uart/uart_component_esp_idf.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/uart/uart_component_rp2040.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/uart/uart_debugger.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/web_server/list_entities.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/web_server/web_server.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/application.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/color.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/component.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/component_iterator.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/controller.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/entity_base.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/log.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/string_ref.cpp.o
Compiling .pioenvs/pana-hz25tke/src/esphome/core/util.cpp.o
Compiling .pioenvs/pana-hz25tke/src/main.cpp.o
Building .pioenvs/pana-hz25tke/bootloader.bin
Generating partitions .pioenvs/pana-hz25tke/partitions.bin
Creating esp32 image...
Successfully created esp32 image.
Compiling .pioenvs/pana-hz25tke/lib4e1/AsyncTCP-esphome/AsyncTCP.cpp.o
Compiling .pioenvs/pana-hz25tke/libf28/WiFi/WiFi.cpp.o
Compiling .pioenvs/pana-hz25tke/libf28/WiFi/WiFiAP.cpp.o
Compiling .pioenvs/pana-hz25tke/libf28/WiFi/WiFiClient.cpp.o
Archiving .pioenvs/pana-hz25tke/lib4e1/libAsyncTCP-esphome.a
Indexing .pioenvs/pana-hz25tke/lib4e1/libAsyncTCP-esphome.a
Compiling .pioenvs/pana-hz25tke/libf28/WiFi/WiFiGeneric.cpp.o
Compiling .pioenvs/pana-hz25tke/libf28/WiFi/WiFiMulti.cpp.o
Compiling .pioenvs/pana-hz25tke/libf28/WiFi/WiFiSTA.cpp.o
Compiling .pioenvs/pana-hz25tke/libf28/WiFi/WiFiScan.cpp.o
Compiling .pioenvs/pana-hz25tke/libf28/WiFi/WiFiServer.cpp.o
Compiling .pioenvs/pana-hz25tke/libf28/WiFi/WiFiUdp.cpp.o
Compiling .pioenvs/pana-hz25tke/libeab/FS/FS.cpp.o
Compiling .pioenvs/pana-hz25tke/libeab/FS/vfs_api.cpp.o
Compiling .pioenvs/pana-hz25tke/lib8e2/Update/HttpsOTAUpdate.cpp.o
Archiving .pioenvs/pana-hz25tke/libf28/libWiFi.a
Indexing .pioenvs/pana-hz25tke/libf28/libWiFi.a
Compiling .pioenvs/pana-hz25tke/lib8e2/Update/Updater.cpp.o
Compiling .pioenvs/pana-hz25tke/lib6a8/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling .pioenvs/pana-hz25tke/lib6a8/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Archiving .pioenvs/pana-hz25tke/libeab/libFS.a
Indexing .pioenvs/pana-hz25tke/libeab/libFS.a
Compiling .pioenvs/pana-hz25tke/lib6a8/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Archiving .pioenvs/pana-hz25tke/lib8e2/libUpdate.a
Indexing .pioenvs/pana-hz25tke/lib8e2/libUpdate.a
Compiling .pioenvs/pana-hz25tke/lib6a8/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling .pioenvs/pana-hz25tke/lib6a8/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/pana-hz25tke/lib6a8/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/pana-hz25tke/lib6a8/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling .pioenvs/pana-hz25tke/lib3dc/DNSServer/DNSServer.cpp.o
Archiving .pioenvs/pana-hz25tke/lib3dc/libDNSServer.a
Indexing .pioenvs/pana-hz25tke/lib3dc/libDNSServer.a
Compiling .pioenvs/pana-hz25tke/libe6f/ESPmDNS/ESPmDNS.cpp.o
Archiving .pioenvs/pana-hz25tke/lib6a8/libESPAsyncWebServer-esphome.a
Indexing .pioenvs/pana-hz25tke/lib6a8/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/FirmwareMSC.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/HWCDC.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/HardwareSerial.cpp.o
Archiving .pioenvs/pana-hz25tke/libe6f/libESPmDNS.a
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/IPAddress.cpp.o
Indexing .pioenvs/pana-hz25tke/libe6f/libESPmDNS.a
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/IPv6Address.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/StreamString.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/USB.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/USBCDC.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/USBMSC.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-adc.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-i2c-slave.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-misc.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-rgb-led.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-spi.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-time.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-tinyusb.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/firmware_msc_fat.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/libb64/cdecode.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/libb64/cencode.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/main.cpp.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/stdlib_noniso.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/wiring_pulse.c.o
Compiling .pioenvs/pana-hz25tke/FrameworkArduino/wiring_shift.c.o
Archiving .pioenvs/pana-hz25tke/libFrameworkArduino.a
Indexing .pioenvs/pana-hz25tke/libFrameworkArduino.a
Linking .pioenvs/pana-hz25tke/firmware.elf
RAM: [= ] 12.4% (used 40672 bytes from 327680 bytes)
Flash: [===== ] 49.4% (used 907345 bytes from 1835008 bytes)
Building .pioenvs/pana-hz25tke/firmware.bin
esp32_create_combined_bin([".pioenvs/pana-hz25tke/firmware.bin"], [".pioenvs/pana-hz25tke/firmware.elf"])
Wrote 0xeeee0 bytes to file /Users/lars/esphome/.esphome/build/pana-hz25tke/.pioenvs/pana-hz25tke/firmware-factory.bin, ready to flash to offset 0x0
=============================================================== [SUCCESS] Took 258.12 seconds ===============================================================
INFO Successfully compiled program.
