Compile time errors
Hi guys,
Could someone more knowledgeable than me with ESPhome please see where I’m going wrong here.
The errors on compile in Python are:
src\main.cpp:242:7: error: stray '\302' in program
       if (temperature->has_state()) { it.printf(10, 0, my_font, TextAlignTOP_LEFT , %.1f°, temperature->state); }
src\main.cpp:242:7: error: stray '\260' in program
Compiling .pioenvs\esp_poe_test\lib904\AsyncTCP-esphome\AsyncTCP.cpp.o
src\main.cpp: In lambda function:
src\main.cpp:242:24: error: 'class esphome::dht::DHT' has no member named 'has_state'
src\main.cpp:242:65: error: 'TextAlignTOP_LEFT' was not declared in this scope
src\main.cpp:242:85: error: expected primary-expression before '%' token
src\main.cpp:242:106: error: 'class esphome::dht::DHT' has no member named 'state'
And my mashup of code:
esphome:
  platform: ESP32
  board: esp32-poe-iso
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  power_pin: GPIO12
  manual_ip:
    static_ip: 10.0.0.20
    gateway: 10.0.0.139
    subnet: 255.0.0.0
i2c:
  sda: 13
  scl: 16
  scan: True
font:
    file: BebasNeue-Regular.ttf
display:
    platform: ssd1306_i2c
    model: SSD1306 128x64
    #reset_pin D0
    address: 0x3C
    rotation: 0°
    lambda:
      if (id(temperature).has_state()) {
        it.printf(10, 0, id(my_font), TextAlignTOP_LEFT, %.1f°, id(temperature).state);
    platform: dht
    pin: 35
    temperature:
    humidity:
    model: AM2302
    update_interval: 60s
web_server:
    port: 80
Thanks in advance for any tips!
Try adding this after the lambda
    lambda: |-
I’ve marked this solved by micque (thanks micque!) but it turned out that wasn’t the only bad syntax :slight_smile:
Jesserockz on Discord was super helpful with straightening it out. Thanks Jesse!
I was also battling bad sensors that I must’ve damaged earlier on, just to double up on the experience :wink:
Here’s the working code for anyone else’s reference:
esphome:
  platform: ESP32
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  power_pin: GPIO12
  manual_ip:
    gateway: 10.0.0.139
    subnet: 255.0.0.0
i2c:
  sda: 13
  scl: 16
  scan: True
font:
    platform: dht
    pin: GPIO5
    temperature:
    humidity:
    model: DHT11
display:
    #reset_pin D0
    address: 0x3C
    rotation: 0°
    lambda: |-
        it.printf(10, 0, id(my_font), TextAlign::TOP_LEFT, "%.1f°", id(temperature).state);
web_server:
    port: 80
logger:
    level: DEBUG
    baud_rate: 19200
