Complex Conditions Using And + Or
Essentially: if there is motion detected, and the living room light is currently off, and its after dusk, and im not on vacation and neither the chromecast or kodi are playing, then turn the light on.
I was able to get it working without the media player options but adding them to the equation has been the pain.
- id: motion_livingroom_night_on
  alias: Motion livingroom nighttime on
  hide_entity: true
    - platform: state
      entity_id:
       - sensor.livingroomsensor_burglar
      to: '8'
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: light.living_room
        state: "off"
      - condition: state
        entity_id: sun.sun
        state: below_horizon
      - condition: state
        entity_id: input_boolean.vacation_mode
        state: "off"
      - condition: or
        conditions:
          - condition: template
            value_template: "{% if is_state('media_player.nut', 'playing') %}false{% endif %}"
            value_template: "{% if is_state('media_player.pauls_cast', 'playing') %}false{% endif %}"
    - service: light.turn_on
Any help is greatly appreciated. I borrowed a lot of ideas from here:
https://community.home-assistant.io/t/help-with-and-and-or-conditions/
The code validates but it doesn’t run. May be an indenting issue but I can’t figure out where.
First, please update your post using the </> code button in the toolbar. This makes it easier to help since spacing is essential in the configuration files.
ok, no problem.
Did you test the template in developer tools? I wonder why you added \n to template.
yup, I had tested it there. Removed it now.
i think,
  - condition: or
    conditions:
should be
  - condition:
      condition: or
      conditions:
That doesnt validate when i enter it
It is possible to just use one OR condition under your AND section. That would probably be the easiest thing.
In what way?
Right now there is only one or.
Either Cast is Playing Or Kodi is not playing
the and conditions are dusk, vacation, light status
edit: playing to not playing. which was what i actually meant for.
you would do it
   condition: and
    conditions:
      - condition: state
        state: "off"
      - condition: state
        entity_id: sun.sun
      - condition: state
        state: "off"
        value_tempate: "{{ states.media_player.nut.state == 'playing' or states.media_player.pauls_cast.state == 'playing' }}"
the last line is true if either is playing and false if both are not playing, but it’s still an and condition. so all 4 would have to be true in order to trigger.
I think this is what you were looking for.
mta: fixed syntax
I had to change it to reflect “not playing”
{{ states.media_player.nut.state != ‘playing’ or states.media_player.pauls_cast.state != ‘playing’ }}
but no luck
alright… last thing I can think of. Try a one liner
condition:
  condition: template
  value_template: "{{ states.light.living_room.state == 'off' and states.sun.sun.state == 'below_horizon' and states.input_boolean.vacation_mode.state != 'off' and (states.media_player.nut.state != 'playing' or states.media_player.pauls_cast.state != 'playing') }}"
if you take just the {{ states.light.living_room.state == 'off' and states.sun.sun.state == 'below_horizon' and states.input_boolean.vacation_mode.state != 'off' and (states.media_player.nut.state != 'playing' or states.media_player.pauls_cast.state != 'playing') }} and throw it in the template editor it will show True or False. If it’s showing neither then something isn’t there or a state is incorrect.
