Component ANEL PwrCtrl with Hardware Version 6.2?
Hi there,
I’m trying to get my ANEL PwrCtrl switch to work for hours. Maybe specifications changed with Firmware version 6.2?
I added configuration from https://home-assistant.io/components/switch.anel_pwrctrl/ and added switch to a group. Tried all combinations of ports, user/pw, … but this 8-relay-switch is never showing up in hass.io
How can I debug (UDP?) connection with this device?
Where you able to get this working?
Sorry, I just closed my issue on github and forgot to leave a message here.
Yes, in the end I found out that my device blocked incoming udp traffic. So
sudo ufw allow proto udp from 192.168.1.13 port 1077
was all I had to do to get it work.
Hello Martin,
May i ask you witch ANEL PwrCtrl you have? I’ve got the HUT V2 but is doesn’t work with the home assistant plugin. When i came from openhab a year ago i left it. But is isnt still working
Does anybody use the Anel PwrCtrl HUT V2 ??
This is another type of device as the first one.
Kind regards,
Thetmar Wiegers
NET-PwrCtrl HUT V2 doesn’t work in HA. Is there somebody who use a PwrCtrl V2 in HA?
