Component error: sensors - Integration 'sensors' not found
I’m new in home assist and integration as i like looks ok. now i start programming things and first i try is my solaredge integration https://www.home-assistant.io/integrations/solaredge/ and try to convert the values to kWh. I follow the example and configure looks like:
sensors:
platform: template
sensors:
solaredge_energy_this_year_template:
value_template: “{{ (states(‘sensor.solaredge_energy_this_year’) | float / 1000) | round(2) }}”
But then when I check configuration I get failure:
Component error: sensors - Integration ‘sensors’ not found.
What do I do wrong?
Thanks in advance
Wilfried
First, from now on you need to make sure you format your code to display the syntax correctly. put ``` before and after the code.
but this is an easy one. remove the exztra ‘s’ in sensors:
sensor:  #<--from here
  platform: template
  sensors:
Dear Finity,
Thanks and yes it is working now. i did copy sensors including the s. Removed the s and it works thanks.
But as i now i like to change the name in the front-end and therefore i like to use a friendly name as follows:
platform: template
sensors:
friendly_name: “solaredge opbrengst dit jaar in Kwh”
this as i read on https://www.home-assistant.io/integrations/template:
friendly_name string (optional)
Name to use in the frontend.
But i don’t see a change in the front end.
First, you still didn’t format your code correctly again.
Did you restart HA after the change?
Where “in the frontend” are you looking?
Dear Finity,
I know. i learn and in future i will do like this:
  platform: template
  sensors:
          friendly_name: "solaredge opbrengst dit jaar in Kwh"
          value_template: "{{ (states('sensor.solaredge_energy_this_year') | float / 1000) | round(2) }}"
For some reason i did restart and in the lovelace the friendly name wasn’t visible. now i look again and it is ok. maybe page refresh thing :frowning:
Thanks for help. in short time i understand what i do and can program my home assistant
