I have HA 0.118.3 installed on a Raspberry Pi and I tried to add my Roborock vacuum to HA.
I managed to retrieve the token, my vacuum has a static IP address so I think I am all good
This is the first xiaomi device I am configuring on my HA.
I added the correct lines (with correct ip and token) in my configuration.yaml file
vacuum:
- platform: xiaomi_miio
host: 192.168.1.2
token: YOUR_TOKEN
But I get this error when I restart my server (or when I check the config file)
Component error: vaccum - Integration 'vaccum' not found.
I donât have the xiaomi_miio integration installed so I went to Configuration > Integration and tried to add it. I am asked this
However, I donât have a xiaomi gateway, only a roborock. if I select the box, I am then asked to enter the IP and token of the Xiaomi Gateway. I tried to enter the robotock ip and tocken but then get an error
Unknown error occurred
According to many tutorials I have seen, I should not even have to install the xiaomi_miio integration. Do you have any idea what is wrong ?
