I’m trying to update mi HASS running on hass.io from 0.103.6 to 0.104.1 and when i run Check Home Assistant configuration before update i’m getting this error:
Failed config
General Errors:
- Component error: xiaomi_aqara - No module named 'netdisco'
I have many alarm automations with this component so is basic in my hass system. I dont know why is getting me this error, with 0.103.6 is all working well.
Like you i had same error in 0.104.0 and another one with sonoff component. The sonoff error was gone with 0.104.1 but xiaomi_aqara component not. Did you make the update?
So may be my config then? but dont understant why now is working well with 0.103.6, i post my config and please compare with yours if there are something diferent:
And recheck, if it fails again i will try to update after make snapshot, did you updated from ui or from command line? Its my first update and i’m afraid to do throught the ui because i have no log to follow the process, is it?
