Component not found: googlehome?
I am on version .88, why doesn’t this work? Trying to implement google home mini
Component not found: googlehome in check config, this is in my configuration.yaml:
googlehome:
  devices:
    - host: 192.168.1.249
https://www.home-assistant.io/components/googlehome/
Google Home
The googlehome component allows you to connect to your Google Home device using an unofficial Google Home API.
This component will provide:
  • device_tracker platform to track nearby bluetooth devices;
  • sensor platform to track the alarms and the timers.
Configuration
To integrate the googlehome component in Home Assistant, add the following section to your configuration.yaml file:
# Example configuration.yaml entry
googlehome:
  devices:
    - host: IP_ADDRESS
sigh, nevermind, apparently i am on .87 :frowning:
