Component not found: payload
there is an error message? I use Hass.io on my Raspberry.
What is wrong?
Thats my configuration.yaml:
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 52.3736
  longitude: 9.7371
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Europe/Berlin
  # Customization file
  customize: !include customize.yaml
  customize_glob: !include customize_glob.yaml
####MQTT
mqtt:
  broker: 192.168.178.20
  port: 1883
  #client_id: home-assistant-1
  username: LedStrip
  password: LedStrip
light:
  - platform: mqtt
    state_topic: "home/terrace"
    command_topic: "home/terrace/set"
    effect: true
    effect_list:
      - bpm
      - candy cane
      - confetti
      - cyclon rainbow
      - dots
      - fire
      - glitter
      - juggle
      - lightning
      - noise
      - police all
      - police one
      - rainbow
      - rainbow with glitter
      - ripple
      - sinelon
      - solid
      - twinkle
    brightness: true
    flash: true
    rgb: true
    optimistic: false
    qos: 0
input_number:
  terrace_animation_speed:
    name: Terrace Animation Speed
    initial: 150
    min: 1
    max: 150
    step: 10
automation:
  - alias: "Terrace Animation Speed"
    initial_state: True
    hide_entity: False
      - platform: state
        entity_id: input_number.terrace_animation_speed
      - service: mqtt.publish
        data_template:
payload: '{"transition":{{ trigger.to_state.state | int }}}'
####Marlon Status
input_select:
 marlon_status:
   options:
    - standby
    - schläft
    - beschäftigt
   initial: standby
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  # api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
#group: !include groups.yaml
#automation: !include automations.yaml
#script: !include scripts.yaml
####DEVICES
device_tracker:
  platform: nmap_tracker
  hosts: 192.168.178.54
  home_interval: 60
group:
####VIEWS
  default_view:
    view: yes
    icon: mdi:home
    entities:
      - group.schlafzimmer
      - group.wohnzimmer
  schlafzimmer_view:
     view: yes
     entities:
      - media_player.mein_zimmer
  wohnzimmer_view:
     view: yes
     entities:
      - group.wohnzimmer
  familie:
     view: yes
     entities:
      - input_select.marlon_status
####GROUPS
  schlafzimmer:
     entities:
      - light.mein_zimmer
      - input_boolean.schlafzimmer_lockout
  wohnzimmer:
     entities:
      - input_boolean.wohnzimmer_lockout
      - light.mein_zimmer
  umgebung:
    - sun.sun
    - sensor.yr_symbol
Thx for help!
This is probably not formatted correctly.
You do not have your spacing correctly in your configuration.yaml for that line. payload needs to go within the automation > “Terrance Animation Speed” > action > data template. as it is now, it is outside the scope of the automation.
Simply put, it is a spacing error.
