Could someone help me?
After a restart a lot isn’t working anymore.
Config checker keeps on loading and when i press the restart button i get a notification saying i got a problem in my config.
Does anyone understand this log?
Home Assistant release with the issue: 0.97.1
Last working Home Assistant release (if known): 0.97.1
Operating environment (Hass.io/Docker/Windows/etc.): Hass.io running on RPI3
Component/platform: Multiple
Description of problem:
After a restart almost all of my components that depend on internet broke.
Problem-relevant configuration.yaml
entries and (fill out even if it seems unimportant):
Part of my log
2019-08-13 22:36:00 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/customize.yaml contains duplicate key "device_tracker.google_maps_116461996308389920595". Check lines 131 and 163.
2019-08-13 22:36:01 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for blueiris which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-13 22:36:07 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for mind which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-13 22:37:06 ERROR (SyncWorker_11) [homeassistant.util.package] Unable to install package https://github.com/bramkragten/python-mind/archive/master.zip#python-mind==0.0.5: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x756362d0>: Failed to establish a new connection: [Errno -3] Try again')': /bramkragten/python-mind/archive/master.zip
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75636690>: Failed to establish a new connection: [Errno -3] Try again')': /bramkragten/python-mind/archive/master.zip
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x756362f0>: Failed to establish a new connection: [Errno -3] Try again')': /bramkragten/python-mind/archive/master.zip
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x756368d0>: Failed to establish a new connection: [Errno -3] Try again')': /bramkragten/python-mind/archive/master.zip
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x756321f0>: Failed to establish a new connection: [Errno -3] Try again')': /bramkragten/python-mind/archive/master.zip
ERROR: Could not install packages due to an EnvironmentError: HTTPSConnectionPool(host='github.com', port=443): Max retries exceeded with url: /bramkragten/python-mind/archive/master.zip (Caused by NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x756328f0>: Failed to establish a new connection: [Errno -3] Try again'))
2019-08-13 22:37:06 ERROR (MainThread) [homeassistant.requirements] Not initializing mind because could not install requirement https://github.com/bramkragten/python-mind/archive/master.zip#python-mind==0.0.5
2019-08-13 22:37:06 ERROR (MainThread) [homeassistant.config] Package mind setup failed. Integration mind unable to install all requirements (See /config/integrations/mind.yaml:3).
2019-08-13 22:37:07 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for zigbee2mqtt_networkmap which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-13 22:37:07 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for breaking_changes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-13 22:37:07 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-13 22:37:10 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for syncthru which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-13 22:37:10 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for pushover which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-08-13 22:38:45 ERROR (SyncWorker_10) [homeassistant.util.package] Unable to install package pysyncthru==0.3.1: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x757539b0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysyncthru/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x757461f0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysyncthru/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75746fd0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysyncthru/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75746b30>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysyncthru/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x75743fb0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/pysyncthru/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7569d8b0>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/armv7/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7569d6d0>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/armv7/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7569d1d0>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/armv7/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7569da90>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/armv7/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0x7569db10>: Failed to establish a new connection: [Errno -3] Try again')': /alpine-3.10/armv7/
ERROR: Could not find a version that satisfies the requirement pysyncthru==0.3.1 (from versions: none)
ERROR: No matching distribution found for pysyncthru==0.3.1
2019-08-13 22:38:45 ERROR (MainThread) [homeassistant.requirements] Not initializing syncthru because could not install requirement pysyncthru==0.3.1
2019-08-13 22:38:45 ERROR (MainThread) [homeassistant.config] Unable to install all requirements for sensor.syncthru
2019-08-13 22:38:55 ERROR (SyncWorker_18) [homeassistant.components.google.calendar] Unable to connect to Google
2019-08-13 22:38:55 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall google.scan_for_calendars (c:7fbf0be4e3af4ffdba733bd3d76237ef)>
Traceback (if applicable):
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 249, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 417, in async_device_update
await self.async_update()
File "/usr/src/homeassistant/homeassistant/components/template/sensor.py", line 220, in async_update
self._state = self._template.async_render()
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 215, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.7/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.7/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
TypeError: unsupported operand type(s) for -: 'NoneType' and 'float'
2019-08-13 23:14:03 WARNING (SyncWorker_7) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6e04bbb0>: Failed to establish a new connection: [Errno -3] Try again')': /v3/circles.json
2019-08-13 23:14:11 WARNING (SyncWorker_18) [urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6e11a050>: Failed to establish a new connection: [Errno -3] Try again')': /v3/circles.json
2019-08-13 23:14:11 WARNING (MainThread) [homeassistant.components.buienradar.sensor] Unable to retrieve json data from Buienradar.(Msg: Cannot connect to host data.buienradar.nl:443 ssl:None [Try again], status: None,)
2019-08-13 23:14:16 WARNING (SyncWorker_18) [urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6e0faa30>: Failed to establish a new connection: [Errno -3] Try again')': /v3/circles.json
2019-08-13 23:14:21 ERROR (MainThread) [pyhaversion] Timeouterror fetching version information from PyPi,
2019-08-13 23:14:21 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.potential_breaking_changes fails
File "/config/custom_components/breaking_changes/sensor.py", line 29, in async_update
await update_data(self.hass)
File "/config/custom_components/breaking_changes/__init__.py", line 113, in update_data
remoteversion = pypiversion.version.split(".")[1]
AttributeError: 'NoneType' object has no attribute 'split'
2019-08-13 23:14:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 825, in _resolve_host
self._resolver.resolve(host, port, family=self._family)
File "/usr/local/lib/python3.7/site-packages/aiohttp/resolver.py", line 30, in resolve
host, port, type=socket.SOCK_STREAM, family=family)
File "uvloop/loop.pyx", line 1464, in getaddrinfo
socket.gaierror: [Errno -3] Try again
Additional information:
