Hi all, the setup for the ConBee II says to use /dev/ttyAMA0 as the device in deCONZ, but when I select that one, I get NOT CONNECTED under FIRMWARE
If I switch the device to:
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2430957-if00
then it works correctly. Should I be using that second device?
Thank you!!
