Conbee II with Deconz, can't add devices anymore after migration to Zigbee2Mqtt and back to Deconz
My setup:
Windows 10 on NUC and VMware player with Home Assistant, latest firmware, works fine for a year with Conbee II and Deconz and 2 Aqa temperature sensors.
Last time I bought 2 Blitzwolf smart plugs, they can connect in Deconz but had no power consumption options by default, so I’ve installed Zigbee2Mqtt and disable Deconz.
I’ve paired my two Aqa sensors and Blitzwolf smart plugs without any problems. It works fine for about 2 days. After that, I didn’t receive any updates from the devices whatever I tried.
So I’ve removed Zigbee2Mqtt, delete al the devices in Home Assistant and install Deconz again.
Deconz is working fine but I can’t connect one of my devices. Searching and searching but no response. I’ve tried in with 2 Aqa sensors and 2 Blitzwolf smart plugs but neither can’t connect to Deconz, Deconz didn’t find anything.
Things I’ve tried:
  • Update Conbee II firmware in Windows.
  • Delete all the Deconz stuff in Home Assistant and reconfigure it.
  • Several times restart of Home Assistant.
  • Restart of the complete VM.
  • Searching for any MQQT or Deconz devices in Home Assistant and delete them and installing Deconz again.
I don’t know why Deconz can’t find new devices, any idea?
Thanks!
Deconz1
i had the same problem over the weekend. ended up giving up and going to ZHA. Have you tried the “secret” menu in phoscon and restoring to earlier settings? If you hold alt while clicking “advanced” you’ll see a menu with previous settings.
I figured it was something to do with previous settings being stored on the conbee stick itself.
Thanks, I’ve tried the secret option in Phoscon without any result.
I’ve installed ZHA, installing is just fine but can’t find any device, I’ve tried several Zigbee devices.
I’ve reinstalled Zigbee2Mqtt, can’t find any devices.
I’ve reinstalled Deconz, can’t find any devices.
I don’t know what is wrong…
Update, I use a long USB-cable now, not directly on the NUC buth with extension cable, now ZHA works fine. Deconz I haven’t tried.
