I have a bunch of radiator valves which show up as climate devices in HA.
They however do not set the HVAC mode (They aren’t true control devices as they do not control the actual heating, just that valve).
I have setup a couple of automations that look like
which works OK but if seems a bit OTT to have to create two automations for each device (not to mention that if I ever want to tweak them to do something else I would need to go in and amend lots of individual automations).
Is there a way I could condense this down? Can I use a template within the set_hvac_mode action and combine both automations into one?
Is there a way I can make this better for multiple devices? A blueprint I guess would allow we me create the automations easily enough but if I wanted to change them I would still be needing to amend or recreate several automations…
Would be nice if I could make this a bit more modular / reusable. How do I do that?
I translated slightly to a blueprint which works OK but obviously won’t work when run manually so I need to wait for the state to change for the automation to trigger.
blueprint:
name: Set TRV HVAC Status
description: Set TRV to Heat / Off depending on temperature
domain: automation
input:
input_trv:
description: The TRV to set
selector:
entity:
domain: climate
trigger_variables:
trv: !input input_trv
value_template: "{{ state_attr(trv, 'temperature') > state_attr(trv, 'local_temperature')}}"
value_template: "{{ state_attr(trv, 'temperature') <= state_attr(trv, 'local_temperature')}}"
condition: []
- service: climate.set_hvac_mode
hvac_mode: "{{trigger.id}}"
entity_id: "{{trv}}"
mode: single
I did try to template the actual value with something like
hvac_mode: >
{% if (state_attr(trv, 'temperature') > state_attr(trv, 'local_temperature')) %}
"heat"
{% else %}
"off"
{% end if %}
but it complained about expecting a string from a dictionary so I guess I can’t put a template here…
Is there a way to do this so that the state will be set if you run the automation and when HA is restarted
needed a slight tweak to state_attr rather than states and had to throw in some float conversions but kind of works. When HA starts the states aren’t there from MQTT and it doesn’t seem to update when they do come through but I will look at that (I think it might just be a missing float conversion)
It does sit uneasy that I have to keep repeating code. I am guessing I can’t nest variables so I couldn’t do
I thought I had answered that in my post, but I must have erased it… Your’s should work, but it wasn’t properly indented.
I don’t think that would work. IIRC, the variable would save the string value with the !inputsubstitution i.e. "state_attr('climate.kitchen_trv', 'temperature')". Then the template {{trv_set_temp}} would just return the string value, not the rendered value of the state_attr() function.
