Sorry if this seems obvious but I am running around in circles, reading through posts of people looking at similar things, yet I can’t get anything to work here. I am looking for an elegant and simple solution, here’s my problem:
Basically I have an automation that opens my gate when I get inside the defined zone. However, at times the phone is a little slow to update location, and I end up having to open my gate with the old remote. I’ll drive in, close the gate, and then on occasion the automation will then finally be triggered, re-opening the gate…
I’ve been looking to add a condition to the automation : I need to make sure the gate status (open/close) has not been changed in the last 10min for the automation to continue.
I’ve tried helpers, I’ve tried a template (within template.yaml?) ; I’ve tried getting time/date… So far all failed miserably. “Gate status” does not have a “last_triggered” parameter.
It would be helpful if you posted the automation, or at least described the available inputs… how does the switch mentioned in the title relate to the gate? Does the gate have a sensor that indicates when it is open or closed?
Generally speaking, a switch entity will have a last_changed property that indicates when the state last changed, this information can be accessed either indirectly by adding a for to your State condition OR directly in a template by using the state object method (states.switch.example.last_changed).
alias: Gate open
description: ""
triggers:
- trigger: zone
entity_id: person.xx
zone: zone.home
event: enter
- trigger: zone
entity_id: person.yy
zone: zone.home
event: enter
enabled: true
conditions:
- condition: state
entity_id: binary_sensor.gate_intrusion_2
state: "off"
- alias: Automation has not run in the last 10min
condition: template
value_template: >-
{{ state_attr('automation.open_gate','last_triggered') is none or
(now()-state_attr('automation.open_gate','last_triggered')).total_seconds()
> 600 }}
- condition: template
value_template: >-
{{ now() - state_attr(this.entity_id, 'last_triggered') >
timedelta(minutes=10) }}
enabled: false
value_template: >-
{{ state_attr('binary_sensor.gate_intrusion_2','last_triggered') is none
or
(now()-state_attr('binary_sensor.gate_intrusion_2','last_triggered')).total_seconds()
> 600 }}
enabled: false
actions:
- type: turn_on
device_id: 73cc7b85ade117438821d83d0ceef2f0
entity_id: 07c1d7a28ff1f96ede76211137d2480e
domain: switch
- action: notify.mobile_app_phone
metadata: {}
message: Gate opened automatically - We are on our way home
- delay:
hours: 0
minutes: 5
seconds: 0
enabled: false
mode: single
You can tell by the code my different approaches. Currently the automation.last_triggered works a treat, but of course if I open the gate with the physical remote, that logic no longer works.
This is the sensor “states” info, no last_triggered. This sensor detects any gate opening.
