With the cold weather having arrived in TX, I’d like to have a conditional card show if my pool pump freeze protection is activated. I’d also like to see the underlying temperature from the pool pump triggering it. Both of these values are coming from individual sensors already created by the iAqualink integration.
I am able to display both entities in two lines, but trying to see if instead of the freeze_protection sensor showing ‘Cold’ having it show the air_temp temperature. Not a huge deal, but would prefer this on one line instead of two.
Current card:
Current code:
- type: conditional
conditions:
- entity: binary_sensor.freeze_protection
state_not: 'off'
card:
type: entities
entities:
name: Pool Freeze Protection
secondary_info: last-changed
- entity: sensor.air_temp
icon: mdi:thermometer
What I’d like it to look like:
Guessing I can create a new sensor combining these values, but also guessing this new sensor might use the last-changed property of the temperature vs. the freeze_protection sensor value. Anyhow, thanks in advance!
