Hello, guys; I am stuck trying to figure this one out. I’ve been down, through and back around the rabbit hole.
I have an ESP32, which I am trying to use to monitor and control my swimming pool.
I have the Temperature monitoring working fine using a DS18B20 Temperature Sensor.
A float switch connected to GPIO25 will tell me when the pool level is correct.
A switch triggers a relay on GPIO14 to open and close a water solenoid, which will fill the pool through a water feature.
I use a TP-Link Tapo plug-in GPO monitor / switch to control the timing of the pool filter pump. switch.pool_pump
I have the temperature sensor working.
I can close the “Float Switch” on GPIO25, which in turn triggers the “water solenoid” on GPIO14
I am placing the Float Switch and Temperature sensor inside the pool skimmer box so it is out of site. To achieve an accurate water level, the float switch should only monitor the water level once the pool_pump switch is off, and has been off for a minute or so. And all so turn off the water solenoid when the pool_pump starts. (This is because the pool pump draws so much water from the skimmer box that the level would not be accurate) I want an indication on the Dashboard whether the pool is filling or not to allow me to pick up faults, etc.
Can I achieve this with code? I have tried adding to the lambda, but I got pretty lost in there
. Would automation be a better option?
Thanks for your help in advance.
Bruce
captive_portal:
# Configuration for Temp sensor
# one-wire BUS
one_wire:
- platform: gpio
pin: GPIO4
- platform: dallas_temp
#class: temperature
update_interval: 10s
unit_of_measurement: '°C'
# water solenoid for pool filling
switch:
- platform: gpio
pin:
number: GPIO14
inverted: True
mode:
output: True
pullup: False
# Float Switch / Sensor to trigger filling
binary_sensor:
- platform: gpio
pin:
inverted: true
number: GPIO25
mode:
input: true
pullup: true
#device_class: moisture
on_state:
then:
- lambda: |-
if (id(float_switch).state) {
id(pool_filling_solenoid).turn_on();
} else {
id(pool_filling_solenoid).turn_off();
filters:
# Small filter, to debounce the switch
- delayed_on: 25ms
- delayed_off: 25ms
