Config questions for QNAP installation (newbie)
I just installed HA on my QNAP following this guide. The installation is pretty intuitive, and I could access HA UI from the 8123 port.
I have several questions (maybe silly):
  1. I didn’t need to setup the account. When I opened the page on 8123 port, it logged me in directly. I could logout, but there is no username field, and I could login without passport (or with any password). Is it normal? How could I setup accounts?
  2. How can I enable the Supervisor view? I want to use the Add-on store, since I don’t know how to access these official add-ons besides it?
  3. A guide said under “Configuration” Panel there should be an “Integration” panel there, but it doesn’t show up for me. Is it also controlled by config and not enabled by default?
Thanks!
I believe you’re just installing Home Assistant Core with those instructions.
There appear to be several additional related docker containers in the container store, and I would guess some of these can add that supervisor functionality.
Please let me know if you solve this! It would be so nice to get a simplified way of installing Home Assistant (with supervisor) on QNAP NASes!
