Config two remote buttons to one entity switch
Hi all,
I have a SonoFF 433Mhz bridge which I can use to controlle my sunscreen. I’ve set two options on it, one to lower the sunscreen and one to pull it up obviously.
Now I have two entities in HA called.
  • button.sunscreen_up
  • button.sunscreen_down
They work fine seperately but I would like to intergrate them into 1 switch
  • switch.sunscreen_kitchen
So when I click it and it is up it will go down and viceversa. So it will do the opposite action of the last performed action if this makes sense.
How in the world do I do this, I have no programming experience so I’m a bit clueless how to start something like this.
Thanks!
I think you are looking to use a Template Switch:
# Example configuration.yaml entry
switch:
    switches:
      skylight:
        value_template: "{{ is_state('sensor.skylight', 'on') }}"
        turn_on:
          service: switch.turn_on
            entity_id: switch.skylight_open
        turn_off:
          service: switch.turn_off
            entity_id: switch.skylight_close
And then you can use switch.toggle in your automation’s.
Do you have a way to know the state of the sunscreen, up or down?
With a template switch…
switch:
    switches:
      sunscreen_kitchen:
        friendly_name: Kitchen Sunscreen
        # remove value_template if you don't have a binary_sensor (reed switch) on your sunscreen
        # note: ha will assume all commands are successful
        value_template: "{{ is_state('binary_sensor.sunscreen_kitchen', 'on') }}"
        turn_on:
          - service: button.press
              entity_id: button.sunscreen_up
        turn_off:
              entity_id: button.sunscreen_down
Unfortunatly not.
Both thanks for the reply! I’ll get into this tomorrow! Thanks!
