I’m using MQTT for climate control and have the devices configured like that:
climate:
- platform: mqtt
qos: 2
retain: true
current_temperature_topic: 'az_t/temperature'
mode_command_topic: 'az_t/temperature/set'
mode_state_topic: 'az_t/state'
temperature_command_topic: 'az_t/temperature/set'
temperature_state_topic: 'az_t/state'
With the new “default_config:” option of HA 88.0 I’m getting this warning for each configured device:
Please remove [retain]. (See /home/homeassistant/.homeassistant/packages/fhem_mqtt.yaml, line 5).
Seems to be a bug as “retain” is an essential part of MQTT. But where is it coming from?
Best regards
Oli
