Config.yaml [alias] is an invalid option for [rest_command]
Hi All,
I am trying to get this code working on my HA that is posted here: https://hometechhacker.com/how-home-assistant-runs-my-irrigation-controller/
I added the following to my config file:
rest_command: !include rest.yaml
Then I created the file called rest.yaml
etherrain_login:
  url: http://10.1.1.117/ergetcfg.cgi?lu=admin&lp=pw
stop_irrigation:
  url: http://10.1.1.117/result.cgi?xr
front_yard:
  url: http://10.1.1.117/result.cgi?xi=0:90:0:0:0:0:0:0
south_strip:
  url: http://10.1.1.117/result.cgi?xi=0:0:90:0:0:0:0:0
north_strip:
  url: http://10.1.1.117/result.cgi?xi=0:0:0:90:0:0:0:0
south_backyard:
  url: http://10.1.1.117/result.cgi?xi=0:0:0:0:90:0:0:0
north_backyard:
  url: http://10.1.1.117/result.cgi?xi=0:0:0:0:0:90:0:0
front_plants:
  url: http://10.1.1.117/result.cgi?xi=0:0:0:0:0:0:0:90
all_90min:
  url: http://10.1.1.117/result.cgi?xi=0:90:90:90:90:90:90:90
start_front_yard_irrigation:
  alias: Start Front Yard Irrigation
  sequence:
  - service: rest_command.etherrain_login
  - service: rest_command.stop_irrigation
  - service: rest_command.front_yard
start_south_strip_irrigation:
  alias: Start South Strip Irrigation
  sequence:
  - service: rest_command.south_strip
start_north_strip_irrigation:
  alias: Start North Strip Irrigation
  sequence:
  - service: rest_command.north_strip
start_south_backyard_irrigation:
  alias: Start South Backyard Irrigation
  sequence:
  - service: rest_command.south_backyard
start_north_back_yard_irrigation:
  alias: Start North Backyard Irrigation
  sequence:
  - service: rest_command.north_backyard
start_front_plants_irrigation:
  alias: Start Front Plants Irrigation
  sequence:
  - service: rest_command.front_plants
start_all_irrigation:
  alias: Start All Irrigation Zones
  sequence:
  - service: rest_command.all_90min
stop_all_irrigation:
  alias: Stop All Irrigation
  sequence:
I get the error:
Invalid config for [rest_command]: [alias] is an invalid option for [rest_command]. Check: rest_command->rest_command->start_front_yard_irrigation->alias. (See /config/configuration.yaml, line 15).
I’ve tried playing with it some, but the best I have gotten is the error just moves on down to the next line (when i comment-out the alias line). Any help would be appreciated!
rest.yaml indentation is wrong
  etherrain_login:
  stop_irrigation:
  front_yard:
  south_strip:
  north_strip:
  south_backyard:
  north_backyard:
  front_plants:
  all_90min:
The rest of the code that has an alias you put in the script.yaml file
That was fast! I appreciate it! Solved.
No it isn’t. Not for an include file.
That is the issue.
