I have looked through similar posts, and am convinced there must be a formatting error. After running 'bundle exec jekyll serve --watch" I get the following: “Error: …/_config.yml): mapping values are not allowed in this context at line 117 column 10” I cannot seem to figure out what is wrong with my _config.yml (posted below):
# Welcome to Jekyll!
# This config file is meant for settings that affect your whole blog, values
# which you are expected to set up once and rarely edit after that. If you find
# yourself editing this file very often, consider using Jekyll's data files
# feature for the data you need to update frequently.
# For technical reasons, this file is *NOT* reloaded automatically when you use
# 'bundle exec jekyll serve'. If you change this file, please restart the server process.
# Site settings
# These are used to personalize your new site. If you look in the HTML files,
# you will see them accessed via {{ site.title }}, {{ site.email }}, and so on.
# You can create any custom variable you would like, and they will be accessible
# in the templates via {{ site.myvariable }}.
title: "Sebastian O Rodriguez"
email: "[email protected]"
description: "<h4>Bio:</h4>"
baseurl: "" # the subpath of your site, e.g. /blog
url: "https://sebastian-o-rodriguez.github.io" # the base hostname & protocol for your site, e.g. https://example.com
linkedin_username: "sebastianorodriguez"
github_username: "sebastian-o-rodriguez"
soundcloud_username: "rodriguez-o-sebas"
infoL: "Exploring and Improving peoples' interactions with technology.<br><br>
Currently working in Florida with local companies as a technology consultant, where I create websites,
update record keeping systems, and help companies get up-to-speed with modern business softwares.
Independently working on the creation of easier-to-use music creation softwares. <br><br>
<h4>Contact:</h4><br>
(954) 856 4903 <br>
[email protected]"
infoR: "<h4>Now:</h4> Fort Lauderdale, FL <br>
<h4>From:</h4> Miami, FL <br><br><br>
<h4>What:</h4> Creator<br>
<h4>Focus:</h4> User Experience & Product Innovation
<br><br><br>
<h4>Education:</h4><br> Carnegie Mellon University | PA
<br> College of Engineering <br>
BS Technology and Sonic Product Innovation <br> Minor Business Administration
<br><br>"
projectsTitle: "Projects"
# Build settings
markdown: kramdown
# theme: phantom # Uncomment once published to RubyGems
plugins:
- jekyll-paginate-v2
# Site configuration for the Jekyll 3 Pagination Gem
# The values here represent the defaults if nothing is set
pagination:
# Site-wide kill switch, disabled here it doesn't run at all
enabled: true
# Set to 'true' to enable pagination debugging. This can be enabled in the site config or only for individual pagination pages
debug: false
# The default document collection to paginate if nothing is specified ('posts' is default)
collection: 'posts'
# How many objects per paginated page, used to be `paginate` (default: 0, means all)
per_page: 10
# The permalink structure for the paginated pages (this can be any level deep)
permalink: '/page/:num/' # Pages are index.html inside this folder (default)
#permalink: '/page/:num.html' # Pages are simple html files
#permalink: '/page/:num' # Pages are html files, linked jekyll extensionless permalink style.
# Optional the title format for the paginated pages (supports :title for original page title, :num for pagination page number, :max for total number of pages)
title: ':title - page :num'
# Limit how many pagenated pages to create (default: 0, means all)
limit: 0
# Optional, defines the field that the posts should be sorted on (omit to default to 'date')
sort_field: 'date'
# Optional, sorts the posts in reverse order (omit to default decending or sort_reverse: true)
sort_reverse: true
# Optional, the default category to use, omit or just leave this as 'posts' to get a backwards-compatible behavior (all posts)
category: 'posts'
# Optional, the default tag to use, omit to disable
tag: ''
# Optional, the default locale to use, omit to disable (depends on a field 'locale' to be specified in the posts,
# in reality this can be any value, suggested are the Microsoft locale-codes (e.g. en_US, en_GB) or simply the ISO-639 language code )
locale: ''
# Optional,omit or set both before and after to zero to disable.
# Controls how the pagination trail for the paginated pages look like.
trail:
before: 2
after: 2
# Optional, the default file extension for generated pages (e.g html, json, xml).
# Internally this is set to html by default
extension: html
# Optional, the default name of the index file for generated pages (e.g. 'index.html')
# Without file extension
indexpage: 'index'
### Phantom settings
footer_text: 'Sebastian Osmel Rodriguez'
admin_name: "          Sebastian Osmel Rodriguez"
google_analytics: "" # Update with your own tracking ID
enable_contact: false
#### Phantom Navigation menu
enable_nav: true
- { url: '/projects', text: "Projects" }
- { url: '/resume', text: "Resume            " }
