Configuration editor missing
Okay so I am very new and learning a lot. But I wanted to switch my dashboard to Lovelace to incorporate some custom cards but after I changed some code the tab on the sidebar where the yaml code was is just gone and I don’t know where to find the configuration code again. Can anyone help please? is it just a per dashboard basis or was that configuration tab for my entire home assistant installation?
Do you mean you changed the UI to YAML mode? If so, the frontend configuration is in a file named ui-lovelace.yaml in HA’s config directory.
I found the confirmation directory I just don’t understand how to view and edit it in home assistant again? Like before there was just a page and it was all the yaml code and now its not there
Unfortunately, I can’t help with that. I generally don’t use the UI much for configuration. I do a lot of direct YAML editing.
What type of install do you have? HAOS? If so, I believe there is an add-on that can help edit configuration files. I’ve only dabbled with HAOS, so I don’t remember exactly what the add-on was called, and I think you have to enable advance mode to even see it as an option to install.
