This is literally my first automation that requires YAML editing. In the YAML editor inside the automation, it doesn’t complain of any formatting errors.
Triggering the automation shows no problems, but on the HASS dashboard on the target app browser, I get the popup but instead of showing my video, I get “Configuation error.”
What am I doing wrong?
service:
- action: browser_mod.popup
title: Front Porch
content: null
type: picture-entity
entity: camera.front_porch
timeout: 30000
device_id: d2ab9242428350849390ec3c451f9bc8
Oh jeez, it doesn’t preserve formatting. And none of the icons atop the compose box offer a “code” option.
Then use three tacks (```) on the line above and the line below.
This is from the HASS log, but I’m unconvinced it’s related. It did come up at the same time I manually triggered the automation though.
IPCAM: Unable to parse event from 00:0C:43:E0:1A:55: 'NoneType' object has no attribute 'SimpleItem': { 'SubscriptionReference': None, 'Topic': { '_value_1': 'tns1:RuleEngine/CellMotionDetector/Motion', 'Dialect': 'http://www.onvif.org/ver10/tev/topicExpression/ConcreteSet', '_attr_1': { } }, 'ProducerReference': None, 'Message': { '_value_1': { 'Source': { 'SimpleItem': [ { 'Name': 'VideoSourceConfigurationToken', 'Value': '1' } ], 'ElementItem': [], 'Extension': None, '_attr_1': None }, 'Key': None, 'Data': None, 'Extension': None, 'UtcTime': datetime.datetime(2026, 1, 20, 19, 59, 23), 'PropertyOperation': 'Changed', '_attr_1': { }, '_raw_elements': deque([<Element {http://www.onvif.org/ver10/schema}Source at 0x7f46ddb540>, <Element {http://www.onvif.org/ver10/schema}Source at 0x7f570ceb40>, <Element {http://www.onvif.org/ver10/schema}Data at 0x7f45a52840>]) } } }
Snippet from my contig
dismissable: false
autoclose: false
timeout: 25000
title: "Deur "
content:
square: false
type: grid
cards:
- camera_view: live
type: picture-glance
image: https://demo.home-assistant.io/stub_config/kitchen.png
entities:
- entity: camera.voordeurbinnen
title: Voordeur binnen
camera_image: camera.voordeurbinnen
tap_action:
action: none
- camera_view: live
entities:
- entity: camera.voordeurbuiten
title: Voordeur buiten
camera_image: camera.voordeurbuiten
tap_action:
action: none
- type: tile
features:
- type: cover-open-close
- type: cover-position
entity: cover.hmip
features_position: bottom
vertical: false
- type: tile
features:
- type: lock-open-door
entity: lock.voordeur
vertical: false
columns: 2
I don’t know enough to know how this helps me. Seems to be an entirely different kind of card with multiple entities in it and it also seems to not be an automation and not a browser mod popup.
How did you create the code for an automation which you posted? Where did you take that “service” word? Is it taken from internet? Or created by AI? Have you tried to compose a yaml by using an internal “Dev tools - Actions” page?
you are right, my snippeI was missing one line. check the correction and compare the node and structure
It should get you going with content etc
Not using browser mod myself; seems that the person suggests to fix indentation, right?
title: Front Porch
content:
timeout: 30000
I’m unfamiliar with the “dev tools - action” process. My first YAML editing.
I pieced the code together from various examples on how to make a browser_mod popup for video.
Never, ever AI generated if I post it.
I changed my YAML to
title: Front Porch
content:
timeout: 30000
And still “configuration error” in the popup.
I appreciate your example, but it is so wildly different from mine I don’t know where to start.
Can you UNindent last 2 lines starting from “target”? (move them to left a bit, on the same level as “data”)
I see, go to “Deceloper tools - Actions” page, select your browser mod service, input data into fields - then switch to yaml, it will show you a valid yaml structure.
As I said, not using browser mod myself, just trying to help you with making a proper yaml service call.
Same result. But thanks. That’s the kind of clear instruction I really need to get this fixed!
This is what it shows me
dismissable: true
autoclose: false
browser_id:
- d2ab9242428350849390ec3c451f9bc8
content:
title: Front Porch
content:
timeout: 30000
BUT, when I try running it in the dev tools - actions, I get the “configuration error”.
In this code you have not unindented the “target” lines as I suggested.
Or is it the structure which was proposed in “dev tools - actions”?
