Configuration Tab is spinning and NOT loading
I am running latest version of HASSIO (3.11) on RPi 3, and everything functionally is working, however, both “configuration tab” and “Developer Tools” are not loading. When I click on them they are just spin and nothing gets loaded. I eventually give up and go back to a different Tab. Not sure when this behavior started (with what version). It used to be working and never had an issue, and no yaml changes have been made recently.
If I can’t load the “configuration tab” that basically means I can’t create new scripts/automation etc from the UI. Anyone else having this issue?
Clear your browser’s cache and try again
Thanks Tediore! That worked. Awesome!
