Configuration.yaml location on Synology Nas Ha container setup
I setup Ha on my synology Nas using container manager. Worked and I am able to access via url. I cannot seem to locate the confirguration.yaml . I set up the volume.
/volume1/docker/Docker/Homeassistant:/Config:rw
but when I go to this folder there is nothing there.
You put Config
Should be config
File names are case sensative
