Configurator breaks after 0.92 upgrade
With both 0.91 and 0.92 upgrades now - configurator breaks.
Error message “hassio.local refused to connect” and a little cloud graphic.
Previous support worked with the apprent changes related to the ingress capabilities.
Here is my config:
Enables configuration UI
config:
panel_custom:
- name: hassio-main
sidebar_title: Configurator
sidebar_icon: mdi:wrench
js_url: /api/hassio/app/entrypoint.js
url_path: configurator
embed_iframe: true
require_admin: true
config:
ingress: “core_configurator”
I’m also unable to access configurator since updating to 0.92.1. I have configurator 3.2 installed via Hassio. The documentation provided on the configurator page gives an error when trying to save. I’m not able to start the add-on, and trying to access it from the menu gives the cloud graphic and “hassio.local refused to connect” message.
Not sure which way I’m facing now…
Loaded the configurator addon v3.2 and it works but, I now have 2 x Configurators on my menu.
I see two configurators on the menu as well. However, one gives a 502 bad gateway for me, probably because the add-on won’t start. When I try to set up Configurator with the config recommended in the documentation
“dirsfirst”: false,
“enforce_basepath”: false
I get the following error:
not a valid value for dictionary value @ data[‘options’]. Got {‘dirsfirst’: False, ‘enforce_basepath’: False}
If you have an iframe setup for Configurator, remove it. I’ve been unable to start it with the link on the add-in configuration page, either. What DOES work, is configuring an HTTP port (like 3218) on the configuration page, restarting Home Assistant, then opening a new window in your browser at http://home-assistant-IP:3218/ It should ask you for your username and password, then display the good old Configurator screen you all know and love. Good luck!
I installed a new home assistant 0.92.1 through docker.io. Added addon configurator 3.2 via Hassio. When you start Open Web UI on the configurator page, it gives error 502: Bad Gateway. I tried the recommendations indicated in the branch, but they do not help. Help please advice. Thank you in advance.
My logs see below
Log
[15:39:54] INFO: Add-on running PANIC: unprotected error in call to Lua API (bad light userdata pointer) INFO:2019-05-02 15:39:55,823:hass_configurator.configurator:Starting server INFO:2019-05-02 15:39:55,825:hass_configurator.configurator:listening on: http://127.0.0.1:80
System log
19-05-02 11:26:19 INFO (SyncWorker_11) [hassio.docker.interface] Restart homeassistant/raspberrypi3-64-homeassistant
19-05-02 11:26:53 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-05-02 11:34:30 INFO (SyncWorker_1) [hassio.docker.interface] Restart homeassistant/raspberrypi3-64-homeassistant
19-05-02 11:34:57 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-05-02 11:39:50 INFO (SyncWorker_8) [hassio.docker.interface] Stop addon_core_configurator application
19-05-02 11:39:51 INFO (SyncWorker_8) [hassio.docker.interface] Clean addon_core_configurator application
19-05-02 11:39:53 INFO (SyncWorker_1) [hassio.docker.addon] Start Docker add-on homeassistant/aarch64-addon-configurator with version 3.2
19-05-02 11:40:03 ERROR (MainThread) [hassio.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:8099 ssl:None [Connection refused]
19-05-02 11:43:14 ERROR (MainThread) [hassio.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:8099 ssl:None [Connection refused]
19-05-02 11:48:32 ERROR (MainThread) [hassio.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:8099 ssl:None [Connection refused]
How do you do this?
This may be the same symptom coming from a different cause, but I found an answer to the same problem.
I started getting the 502: bad gateway error after an update. A little poking around revealed that Configurator needed to be turned on again as one of my add-ons. After I restarted Configurator, it started loading as normal.
