Hello.
I have installet duckdns on my rpi.
I can get into HA, but I can not get in to configurator.
I get this error.
Hello.
I get this error.
i’m not sure it is possible because HA and configurator didn’t use the same port
Have you allowed your IP? it’s not 192.168.0.x anymore but your unique IP.
Google what is my ip and you’ll get it.
It’s not the port.
Can you show your config for the configurator?
The problem is most probably you access HA via SSL but the iFrame is set for non ssl http. The docs explicitly say you can’t do that. If you use ssl for HA you need to use it for configurator iFrame as well. You would then also need to forward port 3218 on your router.
You should be able to use http://ip-address:3218 in a different browser window - not an iFrame.
Did you have a look at the log of the addon? I’m fairly confident it will tell you, that the client IP is not within the allowed networks.
Hey guys. Thanks for input.
I’ve trued to follew the steps in this video from Juamtech.
https://www.youtube.com/watch?v=VUTPAoB27iQ&t=56s.
Here is screenshot of the configuration.
Its working.
Thanks again:-)
